Guys,
I need to know if my car has LSD in it as its a R33 GTS4 non-turbo(all stock standard). I need to know this cuz wanna change my diff oil, and if this has lsd then I cant use Motul gear 300, next option will be redline 75w90 (NOT 75W90NS)?
if there is no LSD then no prob I can use Motul gear 300.
How about front diff? does it have LSD, for front diff 75w-90 is ok too?
Cheers
https://www.sau.com.au/forums/topic/209147-does-r33-gts4-has-lsd/
yea its diffinatly lsd in to back. not to sure about the front tho. iv never had to change oil in mine as it wads done just before i brought it so not to sure whick oil you would use
Ic, Thanks for that, now I wanna know which oil to use for diff with LSD........any specific one you can recomend,,, Motul or redline etc.....but most of them are for non lsd ones....
ring a machanic or workshop of somes sort like hills motorsport. those guys are pritty helpfull over the phone whenever i have a problem. they would know iff the top of there heads...they do alot of work on skylines, rwd and gtrs
no they are not the same as a GTR. as far as I know they have a viscous LSD in the rear and an open diff in the front.
BTW R34GTFOUR, no GTR has a viscous diff in either end. they are a 2 way LSD rear and an open diff front.
hmm well thats gay...
i've got to jack my car up and check this, i thought i read somewhere that all four will spin when your diagnois attessa
mines definately a viscous lsd in the rear, but was never sure about the front.
looks like i need to invest in a 1 way front diff...
mmmmmmmmmm IC , will check tis on Sunday, didnt know how to check so thanks guys. oh by the way I got this Motul FF-LSD TYPE 2 (100% synthetic with complex ester oil) 1L x 4 bottles today, was very dear too ($39.00 per bottle), gona put to front and rear later day, not sure how much I need so got four Ltres...
I think rear like 1.7Ltr? and front should be less than that is it? (Can return if i have any extra bottle to autobarn if I dont use)
if you guys think there are beter oil than this let me know........im always jugle with Motul and redline.......head is still spining :D
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
