[edited by Gary1
if this is the burt i know from qgl boards, then he did own a skyline r33 gts-t, until he sold it to buy an r32 gtr (well thats what i heard), i have seen pics of his car and i must say its one of the nicest r33's i have ever seen, so i think you should retract your somewhat idiotic statement
zoix is 21 and owns 2 houses and his car
and ur saying a turbo r33 is only worth $15k?? plz tell me where ur looking cause im gettin one next year and im expecting to pay $17-$18k for mine
paragon is gettin an 32 gtr there was a mix up
Edited by Gary1
Guest mikstar
everybody is entitled to their own opinion. If you're investing a great deal of money in a car whether it be a new car or an upgrade on an existing car, you need to make a careful decision.
what other people have to say about previous experiences with a mechanic or dealer can often be your best indicator about whether they are good value for money.
do what you want. if you make a poor decision you will get ripped off.
I personaly havn't had any experiences with F&F, but I have friends that have.
This thread sounds like a bitchy little school boy war of words so I shouldn't even waste my energy typing.
But for people who are genuine car enthusiasts and care about their car like I do... make careful decisions and be informed.
People there is no need to carry on the way that you all have been. These forums are not here for you to abuse the crap out of each other.
Please keep it civil.
Think of what a person of the general public would think if they read your posts....And then think of what they will think of SAU. We are not a bunch of silly little girls that want to call each other names and make accusations.
Once agian Please keep it civil
Thank You
Gary
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
