Hey guys,
Whats a good place in Sydney to get a boot lip wing for a 33 gtst?
I have a series 2 wing on it, however am pretty keen for a change in looks and have always loved the look of those wings.
Anyone know where to get them or prices?
cheers,
Chris
https://www.sau.com.au/forums/topic/209257-so-im-after-a-new-rear-wing/
Hey guys,
cheers,
Chris
oh you ricer!!!!
We will be releasing our Carbon Fibre version very soon (RRP is $199 FRP and $299 Carbon, uses existing holes and will be the easiest to install thanks to the bolts already in the wing that line up with the existing holes) :laugh:
PSI Parts - cheers mate, if you could keep me updated that would be tops!
Carbon would be good, but theft risk not so good :D
James - hahah you can talk GTR wing boy!! lol
I had a chat with the toy shop at Newcastle, they are getting some in also but all 2nd hand. PSI Parts, yours brand new yes?
anything in the works for r32 shane?
Yes, although mainly interior at the moment. Stay tuned.
I doubt theft would be of huge concern as it's bolted pretty solid to the bootlid. Yes these are brand new. Keep in mind that the Carbon one will not need painting.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
