Guest RedLineGTR
Try some products like Meguires(Sp)...or maybe a cut and polish..check some detailers usally they can get simple work done like thay for about $100 bucks dont know what sort of job they would do. See if anyone can lend u some products they use...you might only need one or two, test it on the car and check the result.
yep go the meguiars!also if you have a buff do the car first with 3m finesse it.follow this up wih some meguiars swirl remover,if there is still some swirls but unlikely,then finish off with some gold class wax in paste form not liquid,& should be fine.if you dont have the buff just leave that step out.
cheers
warrick
its a product put out by 3m.it is a finishing compound that has no wax or silicone in it. i have used it for years when i had my detailing business.it is made to be used with a buff,although you can do small spots by hand & still get satisfactory results,it is best suited to buff work.it is quite expensive though about $60 a litre from memory although this would last you probably a couple of years.
cheers
warrick
never machine polish a black car as this will give u swirl marks, the best way to get rid of them is 2 coats of meguiars swirl remover and then a wet look polish, lots and lots of hours in this as it all needs to be done by hand but it will do the trick sweet. Swirl marks are almost inevitable on a black car but this is the best cure ive found as told by a very experienced detailer.
if u realy want to u can use a very fine compound with a buff and when u finish use cornflour that will take everything out i can assure u but if u never used a machine before u got to be very careful . of course a hand job will always be better but it will take u all day to do one panel , with a buff u will do the car in like 4 hours
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
