hey guys
ive post this thread in forced induction but no1 has replied so im guessing no1 has used 1....
i can get 1 in box brand new for 40 bucks, i havent seen it so i dont know its model. but its good for 350hp+.
any1 used a hks fuel pump b4???
cheers.
https://www.sau.com.au/forums/topic/209443-hks-fuel-pump/
HKS make fuel pumps. Most are rated between 250l/h and 280l/h
See here.... http://www.nengun.com/hks/fuel-pump
rebranded bosch pumps though. You dont know it's history, it may well be Mcbollocksed...
Go Buy New Bosch 040 for $180 - $220, and be done with it. Peace of mind that there's a fresh pump in there.
https://www.sau.com.au/forums/topic/209443-hks-fuel-pump/#findComment-3705929
hey R31 drift pig....are the bosch 040's in tank pumps by that i mean you dont have to make any brackets or anything like that for it...and it would just replace the stock one.....also are the 044's in tank pumps mate....i am thinking of getting one for my r33 and just need some guidence....
cheers
krish
https://www.sau.com.au/forums/topic/209443-hks-fuel-pump/#findComment-3706525
Walbro - Intank and requires no mods. - $160 or so brand new
Bosch 040 - Intank and *may* require some slight mods to fit in the cradle (Put a couple in S13's and they needed a few cradle mods to go in, Havent done a 32/33/34 skyline) - $180 - $220 brand new
Bosch 044 - External pump, 600HP rated, Will need bracket to mount pump - $220 - $250 brand new.
Best options are walbro (But make sure it's a genuine one) or a Bosch 040.
Ill be switching from my walbro to an 044, As Ill be running a 2.5 ltr surge tank, and need an external pump after a surge tank.
https://www.sau.com.au/forums/topic/209443-hks-fuel-pump/#findComment-3706805
well the story goes he brought in a whole bunch of brand new shit, still in box etc. obviously stolen, so im guessing the dude jusst wanted to get rid of it straight away. plus if he was a junkie i dont rekon he'd know how much a fuel pump would be :S when its ready for sale ill go look at it.
https://www.sau.com.au/forums/topic/209443-hks-fuel-pump/#findComment-3706989
You want to buy knowingly stolen goods? :P:)
Buy new and be done with it I say. Want a cheaper pump? Buy a 2nd hand GTR pump from an importer and have it tested.
Yeah I've got an R34 GTR V-Spec in-tank pump that I just removed for mods.......worked fine and hasn't done much work so if you get stuck PM me
https://www.sau.com.au/forums/topic/209443-hks-fuel-pump/#findComment-3707776
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
