Hi guys unfortunately i have a friend who has to sell & doesnt have internet access so please call.
Price $13,000. well priced i believe
Okay its a 96 Model Series 2 GTST with 101,000kms & rego till November Located in Sussex Inlet (NSW South Coast)
This car has only 2 owners since being in Aus, both of which i know very well & i can vouch that this car has been looked after. Previous owner bought the car with around 40,000km from an import yard in Sydney.
This car is the reason i bought my R33!
PH) :0416 095 659
Sunroof
Genuine Skyline mats
Pioneer Dolphin Cd Player with a sub in the boot
Turbo Timer
GFB blow off valve
Hybrid cooler with Plazmamann Piping
Exedy Clutch
3'' Stainless Exhaust with X-force Muffler
Pod Filter
Autometer Boost Gauge
Good clean condition in and out, if you are after a nice series 2 gtst with a sunroof & some base mods this car is for you, the prevous owner performed the current mods.
The car does not come with the 18'' Impuls in the pictures, will be sold with standard 16'' rims painted black.. Please call for any info
P.S no swaps or dumb offers
These are all the pics i have of the car.
$13,000
Please call if you are genuinly interested.
Cheers Billy
https://www.sau.com.au/forums/topic/209458-fs-r33-gtst-s2-silver/
No way Bert , not yet anyway might keep it & eventually get a 32gtr also. Time will tell, i love my car.
Thanks for the comments buddy. :)
Hey mate you interested in a swap for a single turbo high hp soarer ?
http://www.carsales.com.au/used-cars/priva...amp;Make=TOYOTA
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
