  • Replies 161
ok guys, what im thinking of doing is just pushing the dinner back a few weeks and still doing something this saturday night. Thinking chalkers pool hall for a few drinks, few games of pool, good atmosphere, most of the time good music. What people think?
If you push the dinner out a few weeks I should be able to make it then.
Otherwise you could try getting into Earl of Lester which is just south of the off of Duthy St? again, 30 may be awkward?
ok dinner is now pushed back to the 12th April, same time, same place. Sorry for this guys but first time ive tried to organise anything this large and didnt realise i would have to book further in advance. You will just have to wait another few weeks for your schnitzel challenges :ninja: consider it more training time or something lol.
And a new thread will go up for the pool hall on Saturday night.
ok dinner is now pushed back to the 12th April, same time, same place. Sorry for this guys but first time ive tried to organise anything this large and didnt realise i would have to book further in advance. You will just have to wait another few weeks for your schnitzel challenges :ermm: consider it more training time or something lol.
i wont be able to make the new date at this point :ermm: already committed to an army weekend and need that cash at the moment (and operating hours). If we're doing the planned on-base work that might change, but wont know for a couple of weeks at least
saturday night im still up for chalkers tho
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
