Item: 1996 SII R33 Skylines gts-t M-spec (i think)
Condition:broken
Contact: PM me!!!
Comments: Most interior Parts available!!
The car is White complete with front hit, airbag deployed PM if theres something you need but dont see on the list, im unsure on some prices so hit me up!! PREFER LOCAL BUYERS!!
im keeping running gear/brakes... and prefer to keep the car rolling for the moment!
Type M side skirts $160 small crack bout1-2inchs on front bend
Type M boot spolier/boot $200 good condition
Doors: can come complete or minus trims/switchs/windows $offers
Drivers gaurd slight scratch on front tip $100
Seats F/R series II good cond. $170 front $100 rear $250 the set
Door trims $60 each
COMPLETE F/R SEATS N DOOR TRIMS $360
Clear side gaurd indicators $70 mint cond. were ON hold but person hasnt got back to me so back up for sale!!
Rear bar with type M pods $150 1 pod is broken on the inner side cant really see it from looking at the car.
rear reo $80
Tail lights mint condition $70 each
Mirrors, good cond. $40 each
Climate control unit $100
rear garnish 'skyline' $40
Elec ariel $40
theres heaps more bits but i cbf going out in the heat at the mo so hit me up if you need anything!!!
Edited by shy_s6
  • Replies 65
Posted Images
master brake cylinder and clutch slavecylinder?
ill be using these sorry
I need an ashtray and the parts of the boot interior. The "carpet" that attaches to the boot itself and the carpet that goes along the back wall closest to the number plate...
no ashtray or boot carpets sorry
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
