This has been mentioned a few times, but also make sure you get 2 mufflers to reduce cabin drone instead of 1 muff 1 hotdog or whatever.
Interested to see what you get as i'm in the same boat but don't wanna spend 1k+ for a jap one.
Edited by webng
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3709707
mmmmm. where to start
ok.
Just Jap sell a bellmouth 3inch stainless steel turbo-to-cat pipe for $220 delivered roughly. get that.
get a high flow cat converter
for the rear, I believe a R33 4door cat-back system will fit BUT it will need around 30cm welded on in length.
you do NOT need 2 mufflers.
A nice 3" straight through muffler (i use a Kakimoto gtr-racing muffler) is fine, best just to get an exhaust shop to fit the front section, measure the back section and then custom bend the pipe section from cat converter to muffler, welding the muffler on for you.
easy.
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3709719
i got a quote from everlast mufflers for a complete system, dump pipe, (bolted strait to the turbo) apparently theres some type that bolts onto the stock pipe :S. high flow cat. and the bak has 3 inch mandrell bent stainless steel with a cannon for $1600. he said he could do a 1200 one using cheaper metals and lower qaulity cat. and if i wanted i could mix and match... what do you guys think of this :S is it just me or is it fu*kn expensive?
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3734330
well i have a split dump, highflow cat and 3.5" Greddy cat back system and i paid roughly the same price from memory......if your going for an aftermarket option then definatly worth spending the extra on a good quality metal pipes mate....its a good upgrade and highly recommend a good quality system...i have had it for a couple of years now and its given me no problems at all....apparently D&T and AAA exhausts are very good with prices and quality workmanship....AAA recently gave my mate a quote on using stainless steel from turbo back $1200
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3734353
I've got an R33 system (twin cannons) about to be fitted to my Stag. I'll take note of any changes/problems and give you guys an accurate account of how it fits.
BTW I'll be throwing on a muffler between the cat and cannons to quieten her down. :D
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3734556
Don't forget, there are different grades of stainless steel.
Some SS systems can still rust easily.
:D
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3734569
Demand and supply.
Lots of people want exhaust work and are willing to pay what the shops ask.
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3735207
go to exhuast technologies and speak to marky, he is good with prices and everyone knows his shop and product, highly rated and great quality, or D&T at salisbury and speak to gav, he is the person to talk to bout import exhuast systems.
https://www.sau.com.au/forums/topic/209732-stagea-exhaust/#findComment-3735935
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
