I was wondering what all needed to be done to an rb26dett to get the car into the 11 second range? Currently done to the car is exhaust,intake,boost controller,clutch.I know i will need to upgrade the fuel system and get a standalone.But are the stock turbos able to get an r32 in to the mid 11's????
Also what transmission upgrade do you guys recommened for a person with not alot of money to throw towards a fully built tranny like a hollenger or something along that line.
https://www.sau.com.au/forums/topic/20979-11-second-14-mile-time/
If you believe Autospeed, you just need to do the exhaust and ECU.
If you don't have a lot of money to spend on the gearbox, then the factory one is more than adequate. It will handle 11 second quarters easily.
the stock turbos might see you to high elevens but youd have to have a pretty perfect run to see much lower than that. See the stockies are only safely good for 250rwkw, i'd say to have a repeatable mid eleven 1/4 youd need aroun 280-300rwkw. A set of low mount ball bearing t28 or hks 2530's or similar and an upgraded fuel system should be all you need. You could stay with stock ecu and just reprogram it but its a bandaid and aftermarket solution is a better option. Tranny if treated nice can cope with high tens. So mid elevens are safe once again if you are a little bit gentle.
I used 34 turbo's before but the N1 Spec. (Totally different from just the 34 ones). At only 0.9bar i could get flat 12's and crack into the high 11's no probls.
Getting a quick car is one thing... getting it to last is another...
To prove my point.. what i must tell u is that with that turbo i had bigger injectors, fuel pump, full manifold, cam adjusters and much larger cams etc........
oh to answer ure question, the stock turbo MAY get it into the 11's with more than 1.2 bar of boost... but not for long... especially since its an R32 due to the age... Anymore than 1 bar for long periods are just a blown turbo waiting to happen...
Depends on what the car is used for.
If its used for just the street plotting around and the every now and again Traffic Light Grand Prix it will last for quite a while where as if you take it to the track.. Hell it could even go running stock boost. Depends on your luck.
But For the age of the car what do you expect.
Its doing extremely well to crack low 12's high 11's for a 10+yr old car.
Yes, I've read that with the stock turbos, exhaust, air filter, more boost, cams and stock internals...you can give around 250rwkw and run high 11s. But to run lower 11s you'll need upgraded internals and turbos...etc which starts to get real costly. Then for 10s I expect you'd probably need to change the gearbox soon, and that is going to be the real killer.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
