I have an 89 Holden Apollo for sale, its a great little daily and economical on fuel.
Silver in colour, 2.0L/5 speed, P/S, inside is in great condition, slight paint fade on bonnet/roof, new rotors/pads (less than 1000ks old) new alternator/belt, new clutch, just serviced and runs great, remote arm immolibiser.
Rego expires 13 March (couple of days)
Car located in Kingston, will have pics up 2night
$1650ono
Reply/PM
Cheers Ben
https://www.sau.com.au/forums/topic/209869-89-apollo-sedan/
  • 3 weeks later...
