hey there everyone. for deep dish rims is it better to have a bigger lip at the rear than the front? or is there any difference? what do u guys think about this setup its lenso wide track deep dish rims 18x7.5", 60mm lip at the front and 90mm at the rear with 235/40/18 kuhmo tyres?
any ideas anyone?
cheers.
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/
The only reason why the rears normally have more dish is because they can take a wider and lower offset wheel compared to the front. For a wheel that is designed to have dish, you'll have more dish with more width and a lower offset.
Front's also normally have less dish because the face type of the wheels are made to clear larger calipers.
Those wheels sounds like they've come from tempetyres or something like that. The widths are too small/thin for that wheel diameter in my opinion.
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/#findComment-3714528
what alot of people get confused is the terminology of deep dish, and deep lip.
see the rears on that? see how it goes in like a dish? thats deep dish.
that is deep lip.
most people will still call a "deep lip" wheel "deep dish" because thats the common idea of it
Edited by trism
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/#findComment-3720383
that is deep lip.
Bwhahah ! Love the cat
"Im in ur wheelzz stealing ur offsetzzz!"
Edited by KISIN
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/#findComment-3720627
You'll probably never see a car with more dish up front than the rears unless he purposely did that to prove me wrong. There's always more dish at the rear compared to front because the rears can run wider and lower offset wheels. Front's are usually thinner with a higher offset and often have a different face to clear larger brake calipers. This face minimizes the amount of dish the wheel has.
I'm sure there was no need for me to explain that, but for those that didn't know...
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/#findComment-3723862
well just so happens when i get new coilovers ill be runnin 17x9's +22 offset all round on my ceffy
5 stud helped fit these
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/#findComment-3727615
  • 1 month later...
I have no idea how my situation will turn out... I have a R34 GTT 2 door and I'm getting Racing Hart CXR's 19x8.5 +21 on the front and 19x9.5 +35 for the rears. The reason my offset for my front is +21 is because I bought some aftermarket front vented fenders that are 20mm wider than stock. I hope it still turns out lookin good... 15mm should be that big a difference... right?
https://www.sau.com.au/forums/topic/210073-deep-dish-rims/#findComment-3822484
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
