Come on people... grow a pair and come and support the drivers who are braving the 39 degree heat in their hot cars + suits + hot sun that is summer drift at mallala (stupid heat wave....)
its this sat, and its a twilight event, so even if you rock uop at 5 when it starts to cool down a bit, it goes til 9pm, for the brave the action starts from midday.
Quite a few interstaters, new local cars, and new drivers will be at the event, malking it a little more exiting to watch. If you're coming and planning on watching, the heat is bareable providing you prepare for it, lots of sunscreen, bring a mini pool to sit in, a gazebo, an eskey full of cold drinks (no booze... i know it sucks but thats the rules) and your laughing... you can even brinng a wet and wild slide, and whatever like some have in the past lol!
https://www.sau.com.au/forums/topic/210083-g1-this-sat/
  • Replies 46
yeah come on guys, dont be soft, if we can drive in this heat, you can sit and watch, awesome spot to sit is under the grandstands, still an ok view and keeps you out of the sun.
And for the soft ones, come up as simon said, around 5ish and you will still catch the best guys out there and the team drift.
Here is the event schedule for those interested.
G1 Round 1 ‘08
SCHEDULE
9.00am Gates Open
9.45am Scrutineering Opens
11.45am Driver’s Briefing
12.00pm Warm-up and Practice
1.00pm Break
1.30pm Sponsor Rides
1.50pm Practice
2.20pm Qualifying (5 x 20 minute sessions)
4.20pm Break
4.50pm Group 2 First 8 Battles (Second 16 Cars)
5.20pm Group 1 First 8 Battles (Top 16 Cars)
5.45pm Group 2 Quarter Finals
6.05pm Group 1 Quarter Finals
6.30pm Officials & Team Break
7.00pm ‘Group 3’ Drift
7.30pm Group 2 Semi Finals
8.00pm Group 1 Semi Finals
8.20pm Group 1 Battle for Third Place
8.25pm Team Drift
8.40pm Group 2 Final
8.50pm Group 1 Final
9.00pm Presentations
Entry is $20, children under 14 free.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3714383
joel, simon drifts as well as bob jane fit tyres. lol
so very good then, considering they do everything for me with tyres :domokun:
lol kye, i am the former spin king, think matty took over on that one when he started going out :yucky:
hopefully now with the wider rims and tyres on the rear, ill be able to get that rear grip ive been lacking to nail turn 2.... will wait and see.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715046
considering ill be leaving for the track at 8:30, i think myself, flick and lukey (The Boat or HMAS on here, one of them lol) i think we will be by ourselves, lot of people tend to meet at the caltex along pt wakefield rd and go up from there.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715065
so very good then, considering they do everything for me with tyres :D
lol kye, i am the former spin king, think matty took over on that one when he started going out :P
tip for the day: i know its not easy but try and get the right line which enables you to put your front left wheel on the ripple strip, then ride it all the way around, this is the fastest line and also, due to the front lifting up, it puts more grip on the rear tyres, hence being faster :(
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715357
What can I say I am soft :) No way Im going there on a 40 degree day (with an engine that has been sold)
But I do wish you all well...
I might be able to go down after 7pm to see the final battles and say hi.
Tip for the Day#2: Drink LOTS of water!
Tip for the Day#3: Keep an eye on your temp gauges at ALL times!
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715822
hey shaun, know you probly havnt had a chance but will ask anyway, any luck with those tie down straps you mentioned about at the dyno day?
Thanks for the tip simon, turn 2 has been a killer for me since i started drifting, very rarely nail it. Lets hope saturday is a different story.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3717192
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
