Hi All
I have a feeling my throwout bearing on my 90 GTR has gone.
Its making a strange noise when being launched, if I even attempt to slip the clutch it sounds like a giant dragging concrete along on the ground.
It can be heard here:
just as the car launchs
I think its the throwout bearing. How do I fix it? Whats required to get the gearbox off? Is it back-yardable at all or would I be better off saving up until I can afford to pay a workshop to do it?
Regards
Ian
https://www.sau.com.au/forums/topic/210098-throwout-bearing-strange-noise/
if you want to take the gearbox out in the backyard - you're gonna need stands on all 4 corners up as high as possible as well as a sturdy trolley jack to take the weight of the gearbox.
Oh and a second person for sure!!
Good 2-3 hour job, but do-able.
edit: that's for a gtst - no idea how much harder it is for a GTR...
Edited by made_guy
that noise does not sound like throw out to me more of a gearbox noise excessive play quite posiably. if there is a there is a throw out noise best way to test. is have car idling turn off music or what ever u may have going. and listen for any noise's then put your foot on the clutch and hear if any of the noise's go away. foot off the clutch (does it come back)? if so throw out noise lots of cars have some form of throw out noise
My cefiro has the noise above and it could be the input shaft bearing i have been told.
Either that or it is a sub shaft..or something. Does it do this in 4th gear?
true it could also be the input shaft bearing
  • 1 month later...
to be honest, it sound to me like a twinplate. its more than likely just the plates chattering a bit. ive heard/driven many that do it. most of the time its while after the new clutch has bedded in.
Cheers
Jason
