Hi all, i just wanted to ask a question,if anyone can help.
Can one fit the R34 GTR Nismo intercooler onto a R34 GTT or is there a Nismo FMIC one for the GTT,has anyone done this ,also do any workshops in this country sell the Nismo intercooler and if so how much to purchase one here.
much thanks and appreciation.
David
https://www.sau.com.au/forums/topic/210113-r34-nismo-fmic-for-gtt/
Yep the R34 GTR FMIC can be fitted to the GT-T, as mine has been. im pretty sure its its a straight fit, nothing had to be altered or Cut away to fit it. Not sure about the Nismo Intercoolers, dont even think Nismo manufacture Intercoolers anymore, I think they do still make the piping. check out nengun.com. any perticular reason you specifically want a Nismo one?? all the other brands are just as good, if not better.
he must have picked one up off 34 gtr.
Don't mean to steal the thread, but does anyone know how much a 34 GTR intercooler is worth and the best place to get one???
Also do they need holes to be cut to fit in a GTT? Or can the factory holes be used?
Factory holes cant be used. the GTR's piping returns to the drivers side of the engine, where as you know the rb25 piping returns from the passenger side.
I know of one for sale right now, off a R34 GTR and i think its around 400-500 bucks but apparently perfect nick.
so yes, cutting is required to fit a gtr cooler, i would look into other options such as the blitz and arc kits which dont require this
??.. ive pulled my front bumper off to look at this, and nothing seems to be cut away or altered to fit the R34 GTR intercooler..
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
