Hi all I've been a lurker for quite a while now , but I do have a question. I'm in Sydney at the moment for a few days. and I'm in the market for a R33 Sedan. Have found one here and will get out at some time for a look. So..... the question is If I buy out of SA will the car need to get inspected, and what should I expect Has any body gone this route? Thanks for the feed back
Cheers Paul
If the car already has rego in another state you bring it back and it just gets an ID check to make sure its not stolen etc and as long as it doesnt have anything obviously defectable it ought to be fine...
2nd that!
All obvious mods remove, and you'll be fine.
I bought a 32 gtr in dec from melb, heaps of mods done.
Made it look stock, raised coilovers etc, remove gauges, pfc controller, boost etc.
All good, extremely worrying at the time but all i needed was Vin stamped.
Jason
That is not right the car must have a Complince plate if it has not got one you will have to have a full check over if it has all you need is a id check
If its got rego in another state, then it must already have a compliance plate.
Take the car to the Sturt Vehicle Inspection Station if you can, if the car has a few mods. They're not as anal as Regency.
I've gotta do the same for my Stagea, so I'll be going to the Sturt inspection station near the Sturt/Darlington Police Station.
a couple months ago i bought my 32 from VIC..it had vic plates and vic rego so all i had to do was take it to a cop shop, i went to sturt rd cop shop, and just get and id check. However if there are obvious defects such as gauges, too low, tint too dark like mine had they'll tell you to fix them and come back. However tif they believe the car needs to go over the pits coz it has alot of work done to it they will then send u to regency which isnt nice at all lol
good luck man
No just because it has rego and it maybe complied it still has to have a compliance plate on the back of the eng bay of on the inside of the drivers door if it does not have that plate YOU will have to have a full check over
If it has the compliance plate, its complied ... thats what I meant. Please learn to read. :laughing-smiley-014:
I'd rather the car get the full check over. I don't fancy a cop lubing me up :laughing-smiley-014:
Edited by RubyRS4
Just because it has a compliance and it has been complied in another state that does not mean that it will get though here with out a full check SA still has to do a full check on "Imports" that come into SA .And he was talking about a R33If its got rego in another state, then it must already have a compliance plate.A car can have rego in any state and not be issued with a compliance plate
"QUOTE If its got rego in another state, then it must already have a compliance plate. your QUOTE RubyR4"
Edited by puresx
Yeah ... err ... thats what I was saying in the first place :) Glad you agree with me :laughing-smiley-014:
Anyway ... back on topic. Take the car to the Sturt Inspection Station next door to the cop shop and you'll be better off there than Regency, who have a larger capacity to go right thru your car should they deem to.
Edited by RubyRS4
Hey boys now I'm confused.....my thoughts were that you can't get rego in any state without a compliance plate fitted & sighted by an official.
If that is true and this vehicle in question has interstate rego then I would assume that it would have to have a compliance plate fitted.
If that is also the case then a Sturt inspection for eng & vin is all you'll need (Wed & Thur 11am - 3pm & no appointment required).....just make sure there aren't any obvious things like dark tint on front doors, too low, tyres sticking out of guards, pods OK but must be secured, exh hanging on the ground, etc
They won't check ECU, turbos, fmic (unless 1/2 your front bar is cut away) and if exh is loud just idle into the shed.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
