Originally posted by franks
...and once you've owned and raced laggy street cars with big turbo's, its hard to go back too :uh-huh:
my WRX had a TD05 turbo from an MY94 WRX which was large. Subaru went to a TD04 for a reason....lag is your enemy in a street car!!! :(
I'd agree with that one.
I've got a t04e (on an RB25 though)
it hits 9.5psi at 4300... and holds firm till 7000rpm. and makes 190rwkw.
makes boost of approx 4-5psi from around 3500.
So i'm happy with that.
But i see FAT32 what your saying about pushing you into your seat.
If i get traction i get thrown right into my seat only running 9.5 psi.
Soon we get 14-15psi or so running and see what happens.
But you'd notice the 'throw' more on an RB20 I reckon because they rev quite hard.
I had an RB20, with the stock turbo... it was fast and rev'd great but it didn't push you back like you said the t3/4 did.
  • Replies 111
Why would someone put a GT2530 on a rb25 when you need two for an a rb26, they are way to small, those idiots at GCG should not have sold you that turbo, t3/t4 is the only way to if you want to make some real kw's
Have you been for a ride in an RB25 with a 2530? If you have you would see its merits.
If you have been for a ride in an R33 with 2530 and you dont think it makes for a quick car then id hate to be the one paying for your car's mods.
Well all,
After much buggering around I resolved a few of the problems and most were NOT the turbo's fault much to my surprise. The turbo ( R34 GT-T Compressor & Turbine Housings with a GT2530 core ) makes boost early and will hold more than 1.3bar up to rev cut at 8,400rpm so I'm not complaining at all.
I've yet to get the car back on the dyno and do the final tune but when I do I'll be sure to let y'all know how it worked out so future players won't make the same mistakes I did.
I'd also like to say that GCG helped me along the way and were still willing to help further, so no bad words for them.
I had a split gasket on the turbo outlet and didn't have enough thread on the wastegate actuator to preload the actuator enough to keep the wastegate closed under boost so I fixed them and now it seems pretty good.
I also fitted a split dump pipe off the turbo with a divider to seperate the primary exhaust and wastegate gasses which helped.
That is one of the dumbest, unsubstantiated statements Ive heard on this forum for a long time. You successfully made yourself sound like the idiots you claim GCG to be... well done turbogtst, well done.
I strongly suggest you spend many, many, many hours searching these forums to soak up some knowledge, hard facts and others' personal experience before you think about posting again.
Originally posted by nissky
he wants 400rwkw....nah ;p
You betta believe I want 400rwkw but I know it aint gonna happen with this car & on my budget !!
Nissky, Next track day we'll go for a blat and see if I really NEED that 400rwkw:spew:
I wasn't talking about YOU spewing........probably be me :D
Brakes are EBC Rotors and EBC Greenstuff pads and some other basic mods. Also using Motul Synthetic Brake Fluid.
If you really want to see how the brakes work I'll take you out around Wakefield where the back tyres damn near come off the ground.
being the 5th person to quote you, ....
agree with turbo tits. What experience do you have to make such a claim? I would think you would have be pretty qualified to call the very popular and reputable GCG guys "idiots", when they've been involved with turbos for many years. Its one thing to state that you may "think" the 2530 is way too small, but to state "they are way too small" is pretty stupid, as is calling GCG idiots. As mentioned, Turbo selection is all about application, and not just about "real kws".
Sure you may be used to the response and peak power of big turbos, but for those looking for a completely streetable but still quick package, the GT2530 is an excellent choice.
your post isnt going to help anyone actually trying to research this turbo, as its unqualified.
how much power is your car making by the way, and with what turbo?
Go tell all the members who have upgraded to this turbo that its way too small, after all, you would know.
Joel,
So long as your seals etc are in good nick you can go ahead and use synthetic fluid. Keep in mind, it's synthetically manufactured but still has the same basic properties ( but much better of course ) so it should have no adverse effects on your brake system.
You just have to remember that when you change your fluid you've only changed one of the many facets of your brake system so you'll end up with a firmer pedal but MAY then transfer the problem to another place thus giving you the impression that the fluid has caused the problem.
Clint32,
Don't be surprised if you don't get a very good pedal after you change to Castrol SRF as quite a few people I know have found out. I've turned most people I know towards Motul RBF and since then none of us has had any problems.
From what I understand, SRF is great for big brake systems like ARP, Willwood etc but is just not suited to factory brake systems. I only believe this because I've seen it with my own eyes many times. Motul RBF is also cheaper :P
I changed my fluid to Caltex GP600, which is a DOT4 with temperature tolerances surpassing some DOT5 fluids. For example, its boiling point is 310 degrees whereas Castrol's Super DOT4 is 286. Some DOT5's boil as low as 300 degrees. Since it's not silicone based, you don't have to worry about it eating hoses. It costs around $35 a bottle.
This is the fluid recommended to me by Race Brakes in Sydney, and is the stuff they use on their rally cars. So it can't be that bad :P
Edit: wtf? I just noticed this thread was about 2530 turbos. how the hell did we get onto brake fluids? :P
Edit: wtf? I just noticed this thread was about 2530 turbos. how the hell did we get onto brake fluids? :)
That would be Nissky's fault :P
The GT2530 in a T3 Bolt pattern will bolt on a GTST, but it is not designed to be for that car. With the GT25 turbine housing it is designed to be a mild upgrade for the SR motors
They are designed to be for a twin set up on a GTR.
This is why it is a very linear set up on your car.
You would need to run a GT2340 which would be somewhere between the 2530 and the t3/4 that GCG do. However closer to the t3/4
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
