not sure about that one. but if you have or some one else has removed the steering wheel i know the light comes on its a matter of serching the forums to find the answer. The thread is on here i rember seeing it maby try the diy section steering wheel removal
  • 1 month later...
What if you have more than one fault - how can you tell from the flashing lights code?
For instance I know my speed sensor is stuffed in the dash but I am trying to chase a different error...
Dont worry figured it out - To get first code: long flash is first digit, short flash is second digit - so two long flashes followed by one short is code 21 then I got three long flashes followed by three short - Code 33. So ignition fault (assuming speed sensor) then O2 sensor fault (interesting...as o2 mode showed no fault)....
  • 3 months later...
Hey guys i know this threads a bit old but i have a problem getting my diagnostic results. I have a series 2 rb25det engine in a r32 skyline. So no light on the ECU and i tried the paperclip thing but nothing happened - no flashing lights on the dash. Any help would be great...
  • 10 years later...
Hi guys sorry to bring back the past this was very helpful BTW but my prob goes a little deeper currently working on a s chassis power buy rb25det built buy cowboys obviously diag port isn't even present I just wired the engine light end was think am it to gound ecu pin 47 to activate diag mode or will it need to connect with another specific wire
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
