Garrett Gt2860r -5, Gt2860r -7, Gt3071r Turbos
Yes but i want to know exactly how bolt on this turbo is i.e. what needs to be changed or made up to fit this turbo on an rb25. I have been looking around and was thinking about a GT2871r as well little bit smaller for faster spool as i dont want boost on really late so how much can you get a GT2871r.
  • Replies 88
cool, but how bolt on are they, what is needed to be done to get either of these turbos running on a rb25
Mate, i suggest you search in the Forced Induction section. If i'm not wrong, they bolt onto the stock low mount manifold nicely. What you need will be gaskets and maybe some lines for the turbo.
sloutch is just doing us all a favour n getting the turbos cheap. If you want a more details description of what engine the turbos will deff fit, you should do you research yourself. Do a search on this forum or call a garrett specialist.
Edited by Blitz_R33
Blitz R33 - Thanks for being understanding :D
N1GTR - Prices for the 2860 - 10 will be more expensive. They are USD $2,200 delivered which converts to about AUD$2,400 delivered.
GT2871r is not a direct bolt on. different manifold and dump patterns. you'll need an adapter and custom dump.
this is the gt3071r you need.
http://www.tweakit.net/shop/product_info.p...roducts_id=6598
You've got a PM :laugh:
Is there any way to avoid GST and taxes etc? I imagine if we get "caught", it'll be no cheaper than buying them from AUS? Unless I'm missing something (most likely :()
You've got a PM :banana:
Is there any way to avoid GST and taxes etc? I imagine if we get "caught", it'll be no cheaper than buying them from AUS? Unless I'm missing something (most likely :banana:)
PM replied Tommo. :banana:
Yes, you're kinda missing something :yes:
Hey.
Interested in a GT3071r. How much?
What a/r is it?
And is it the real GT3071r?
Thanks
All the turbos sold by my supplier are genuine Garrett turbos. The 'mother' company of Garrett is Honeywell. It is a US based company. They are sold with manufacturer warranties.
GT3071 for T3 flange is AUD$1,500 delivered.
You've got a PM :yes:
Yes, is ther eany way to avoid tax? I was happy at paying $2150 for these until i relased ill get rapped with inport tax.
Edited by Blitz_R33
If we want a fitting kit say for the RB25 are you able to supply them for a decent price on top of the 1500 for the 3071r???
Sorry unfortunately you have to get the kit separately. I don't think it is very pricey if you buy them locally.
Ok, well they are $680 on the Tweakit website...that does seem pricey to me for a couple on lines and gaskits??
Thanks
I'm interested in the 3071 too but would like to know the exact specs of this turbo, wheel trims/housing A/R's etc...... also do we have any options on the specs? That comp cover doesn't look like it bolts up to the RB25 intake, i believe they make one that does, or not?
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
