The v35 will always be a maxima with the rear doors welded shut to me...
but I like your one, the wheels set it off. I saw a v35 with eyelids to make it look like v36 headlights, and I was very tempted...
but I'm hangin out for the v36 lol
  • Replies 44
Hahaha I didnt know you were on here..
Saw ya at Hunter last night. I stopped by for a few drinks with my mate after the photos.
oh really...where was the hello?
lol
yeh man...ive loved skylines since i was like..i dunno...since i bought 1
pfft...i want a 34....
hey i heard ur a mechanic too...when i get sum money 2gether..i want sum mods..
do em for me yeh...cheap
oh and want some advice....$5000
what should i do?
5 g's will pay your tuition and get him some rims man.... DO IT!
lol...yeh i need that too
my cars only got an HKS pod, and Greddy RS bov
ohhh and i replaced my clutch with a Five puck Brassy..wouldnt of done that but my stock clutch went after too many burnouts.
I was thinkin..
1. Turbo back exhaust w/ split dump pipe
2. FMIC..whats ur suggestions..BAR & PLATE, or TUBE & FIN?
3. Boost Contoller & a nice tune!!
I'm not made out of money lol...but i do want somethin that goes good!
I've raced a couple of stock V8's and beaten them...quite happy & surprised. Any faster than that i'll prob kil myself!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
