Hi Guys
Selling my rb2.1 has done less than 4000klm putting car back to standard to sell spec's are
Rb20 block bored 40 thou cracked checked acid cleaned line bored
arias 40 thou oversized pistons
rb26 conrods resized shotpeened and hardened and balanced arp rod bolts
rb25 crank with n1 colar fitted checked and balanced
n1 water pump
n1 oil pump
arp main and head bolts
hks cams 264 9mm lift
hks cam gears gates timing belt
rb20head port and polished with 1mm oversized valves
oil return from head to sump
tomei oil restrictors
no turbo or injectors or ecu
thats about all I can think of atm but will update if I remember anything else, engine has made 306rwkw with only 1800k's on it, in an r32 gtst and has run an 11.7 at wsid on its second outing so there was more in it
Price $6500 which is less than half what it cost to build
location is sydney west
Will update with pics of build a bit later
Cheers Peter
https://www.sau.com.au/forums/topic/210438-eoi-rb21/
  • 1 month later...
  • 2 months later...
I can vouch for this set-up as I have been in the car numerous times.
A really tough and well thought out engine with a lot more left in it.
Someones going to pick up an awesome engine package.
Cheers
Daniel
https://www.sau.com.au/forums/topic/210438-eoi-rb21/#findComment-3991636
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
