Hi guys,
After waiting ever so patiently, and going thourgh the paypal dispute process, Nengun FINALLY sent my turbo.
Now, I've read on many topics that the kit doesn't come with a gasket for in between the turbo and the dump.
Now, I know GTST25 i think it was who posted that you should use coppermix sealant.
Also, I do remember Sly33 made a copper wire to go around the grove and used that as a sealant.
However, I do recall in a thread somewhere (I forgot who wrote it) that someone called HKS Japan and they informed him that you do NOT need a gasket, could this be true?
Because after all, the gasket probably costs around $10, probably less, so why wouldn't they include it? Maybe you don't need one?
I tried contacting HKS USA without success, bloody voicemail thing keeps coming up.
Has asnyone with a HKS GT2835 Pro S not used a gasket?
Cheers?>
https://www.sau.com.au/forums/topic/210445-hks-gt2835-pro-s-turbo-issue/
One guy on this forum - Michael user name I think didn't use a gasket. I used ultra copper and it's been fine for two years.
Good luck with the install and keep us posted - look into using a die grinder on the turbine housing inlet as it's not well matched to the exhust manifold. I didn't but next time it's in bits I will.
Cheers
Cheers
Will it make a difference in terms of performance if you don't grind it you think (ie in terms of flow since it doesn't match perfectly)?
Furthermore, what's ultra copper? DO you have a link to it so I can see where I can get it from?
DO you think it is possible just to buy thin gasket material and cut it out to the shap of the dump flange?
Wow, I can't believe your sealant held up for 2 years, thats good news.
Im using no gasket on my hks 3037 pro s turbo and hks dump, it is exactly the same as the 2835 pro s dump, and i havent had any exhaust leaks around that area, you could use a liquid gasket maker if your a bit parranoid about it,but thats a bit messy, anyway mine is fine.
Don't worry too much about the sealant issue - as I said there's a guy on here that's used nothing. It won't hurt to die grind out the housing to match the manifold to turbine gasket - Dale FZ1 just installed a hks turbine housing on his car and did it. It's just easy to do while it's all in bits. Also while it's apart I'd advise pulling off the exhaust manifold and doing all your studs - a sh@t of a job but who knows you might get it all together only for a week and hey presto exhaust leak.
In saying all this I didn't do my studs or grind out the housing as I was in a rush and it's a pretty quick car. Turbo kit install took a day.
Cheers
Cheers
Yeah I might just use that Ulta Copper sealant.
I'm one paranoid F#$K, I wont be able to sleep knowing that it might be leaking pressure, haha.
I am not installing the turbo myself, I'm paying a shop to install the turbo, my nismo 555 injectors and Z32 all for $800. Is this a good price?
Cheers
The housing design on the hks pro s housings are designed to be gasketless in there nature as in flat surface matching to dump, but as said you can use the sealant stuff on there as well. to install turbo injectors and z32 800 could be about right dependant on mechanic charges, but its allways fun to try and do it yourself, its the only way to learn :P esp if you have to remove it for any odd nature in the near future.
Also curious with this grinding out the manifold flange to match the housing? If anyone gets the change measure the actual length width of mani vs housing just curious on how much in terms of area is actually different.
Cheers
Hi guys,
Cheers?>
hey :P
I am the one who had my mate call HKS in japan for me. Hks sent me 2 gasket which where both the wrong ones and then in the end they finally understood what we were after and said the Turbo doesn't need a gasket. i have been running mine now for 2years without a gasket and no problem at all (251rwkw @ 16psi)
If you look at the rear housing of the turbo you can see it has like a trench, and my understand this makes like a vaccum seal between the rear housing of the turbo and the dump pipe
If the Turbo did require a gasket, HKS would have supplied on accordingly.
Nonetheless, I might just put a little bit of ultra copper on it as I know metal to metal doesn't provide a great sealing.
Thanks for all the repsones boys, you've been very helpful.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
