I had a look at a series 2 R33 gtst this morning and took a few pics. The whole car seems to look pretty decent and it certainly performed well on the test-drive. There were a few odd noises like a metallic scraping sound from one of the rear wheels (worn brake I guess) and an even stranger 'gurgling/grinding' sound from the rear under idle (could not figure that one out), but other than that it seems ok.
One thing I did notice in the engine was an unplugged cable at the front-left (near the radiator). There was also an unplugged lead coming from the engine fusebox. I've circled them both in the first picture. Anyone know what these may be for? The 'green' plug was reconnected before the test drive so I don't know how or what it could have affected. I assume the other lead was for some sort of a/m device that was removed at some stage.
Any ideas about those plugs or are they not worth worrying about now?
https://www.sau.com.au/forums/topic/210467-few-questions-about-a-r33-sii/
one is the engine temp sensor it is located at the botom of the radiator there is another one in the top of the head where the radiator hose joins the block you can drive around with out the green one pluged in it makes no diffrence to performance the other one i cant see clearly enough could be anything.
the metallic scraping sound from one of the rear wheels
may be rust on the stock disks or worn brake pads they are noisy after you wash your car and you get surface rust on them
gurgling sound could be after market fuel pump they are louder some times
or stock one is fked
they are my guesses but i have only had my car for 8 years
best take it to a RACQ or NRMA for a master check just to be sure
any other ramifications of not having that green plug connected? Its not going to let the engine cook or anything is it?
And yeah, I've booked an RACV pre-purchase inspection but, cos of easter, there is a queue. Won't be getting checked til the 26th :P
i beleive the one on the drivers side is a grey one yes? just below the jumpstart thing?
that is a diagnostic port , its not meant to ber connected.
green plug- you will find the other end hanging behind the fan shroud area, and its not a big deal. it seems to be unplugged more than its plugged in. maybe they remove radiator for compliance or something.
i would look into the noises tho. brakes arent so bad, but whatever the other one is could be more expensive
I agree. I kinda sounded like it was coming from the back-left so at first I thought it was the exhaust making a racket. But the sound only really appeared during the test-run. I really don't remember hearing it before the run.
Which side is the fuel pump on?
Could be wheel bearings, easy fix.
To check, jack the car up and spin the wheel and also feel for any rock or movement by grabbing the wheel and pushing and pulling etc.............but it must be jacked up.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
