Hi,
I would like to know if NOS is legal in Victoria,
can i have the setup and bottle or just setup or neither.
let me know if you know how much it would cost to install.
If anyone has a kit for sale let me know.
Thanks
Edited by HTMR32
https://www.sau.com.au/forums/topic/210656-nos/
You can have the fittings in your car but nothing connected and like not even a bottle in your car and just the connection sitting there you can not have it in at all
i do belive you can have c02 in your car i belive but must be engerneerd or somthing or EPA tested depending on where it is fitted can not remember
https://www.sau.com.au/forums/topic/210656-nos/#findComment-3724349
Sorry to say you are incorrect.
Having ANY part of a NOS system installed in a Victorian street car is illegal and you could be fined $2000 PER CYLINDER. That's a $12,000 fine for an rb engine.
https://www.sau.com.au/forums/topic/210656-nos/#findComment-3724446
apparently having the nos kit is legal to have installed and u are allowed to have the bottle put in the car but the bottle cant be connected.
they tried to pass a law for nos bottles to be banned but they cant cause then they would have to ban people from have BBQ bottles in the cant so there is no law for not having the bottle in the car.
they cant fine you if they dont see u using it or if its connected.
thats what i know for now.
https://www.sau.com.au/forums/topic/210656-nos/#findComment-3724570
yeah but Police are the ones who will defect you for anything i had one try to defect my evo 6 for a front mount intercooler and there is now a letter we have from mits that we can print for police who defect Evos for there intercooler and there rego being on the side so police will defect you for anything if they want to
https://www.sau.com.au/forums/topic/210656-nos/#findComment-3724969
Can have the setup, cannot be connected or quickly connected. Otherwise some snap on air line connections could be used. Basicly if you have to get a shifter to put it on then your fine.
Any of you two got proof for what you typed there? Last official documentation I read agrees with Al in that you cannot have ANY part of a NOS system connected to a road rego'd car.
https://www.sau.com.au/forums/topic/210656-nos/#findComment-3726017
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
