Hi all,
After dropping a cylinder (stupid cyl 6 with it's foobarred ring lands....) it's time for me to start some serious research on rebuild options.
Let's start at the top. Not aiming for high horsepower (read 250rwkw MAX) so while I got this thing apart, I may as well build it to reliably run that sort of power. It's a street driven car and my daily runner for work so it sees traffic duties.
Question 1 (there's bound to be more) - Head gasket.
Should I just get a replacement stock item or get a metal one? If I get a metal one (from HKS or the like) should I be considering lowering the compression? Seems the thinnest metal head gasket will result in 9.0 compression ratio. Higher? Lower?
Feedback would be appreciated.
Cheers
https://www.sau.com.au/forums/topic/21089-rebuild-q1-compression-ratios/
Guys, thanks heaps for the replies. Will an 8.6 compression ratio drastically affect off-boost performance? I've also been offered a super deal on some Arias forged pistons and rings (read less than $1300 delivered) through a friend who has contacts over east (no, they're not hot). Is it worth the extra expense given the fact that by the time I buy RB26 pistons and rings to match i'll probably be looking at that sort of dollars anyway?
Bl4cK32: I'm not really interested in an RB30 conversion. Thanks for the idea though.
Chris, cyl 6 has been a little dodgy ever since I've had the car and I guess the problem has just got worse. It has also been running quite lean. In terms of prevention, I'd simply say make sure your car is in a good state of tune. Something I neglected to do upon purchase of my car. Get the A/F ratios analysed to make sure it's not leaning out. As for intercooler, I was considering the Trust cooler as people suggested in my other thread however, $$ now have to go to get it rebuilt. :P
All, particularly, Meggala, I have just been informed by one of the performance shops over east, who have it on good word from a reputable performance shop (yeah i know, second hand knowledge) that putting RB26 pistons into an RB25 causes detonation on low boost and will cronically wreck your engine.
Thoughts?
SeriesIIGTST, for 250 rwkw stick with as close to 9 to 1 compression ratio as you can. Off boost performance and fuel economy drop off dramatically with lower compression ratio, as does throttle response and boost build.
To help the #6 problem, get the injectors flow tested and put the highest flowing one in #6, the next in #5 etc.
Hope that helps
Depends what you are after.. I'm only after 250rwkw's.
Check out Raists dyno run of the before and after with the RB30..
Here's the dyno run.... Look at the RPM compare.
http://www.skylinesaustralia.com/forums/at...=&postid=444741
For a street car you really can't beat the RB30 conversion for its response and considering the price is very similiar to rebuilding the RB25DET.
Warpspeed.. You sound like you are beginning to get annoyed with the RB30 suggestion.. heheh :)
Go a Rb30 bottom end .... very cheap and new pistons from toda are as cheap as too.... rings and bearings from AVO and youll just need a new after market ecu...
done....
Oh and a new turbo HKS 2540
Not serious power 400+kw's.......HEHEHE
Steve: I don't know a lot about engines at all and the guy started to explain something about them being too high or something. This info has come from the people who are supplying me with forgies if i decide to get them. Anyone care to comment on Arias pistons and rings?
Too high? I was under the impression that the gudgeon pin in a RB26 is closer to the crown of the piston than on an RB25. As megalla pointed out, it would result in a lower CR
If someone is trying to sell me something, generally I believe 2/5s to fark all of what they say. I will listen to what they say, but alot of time people who are trying to sell you stuff do it because they want to make some money. If I were you I would as somewhere else, as GTR pistons will probably cost half or 1/3 of the cost of forgies (therefore 1/2 - 1/3 the profit for the salesman)
I am not knocking what you have said, just find it hard to believe that there is a problem as the design of the head for RB26 and RB25 is very similar, ie same casting as far as I know. But if this is genuinely the case, that would be good info.
I am a bit of a sceptic at heart:)
As far as I know, Arias, Wiesco, JE - all good pistons, ie I have never heard any bad about them and it wouldnt make alot of difference which one you chose if you are chasing 250rwkw.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
