My gtr has got squeeky brakes and it is p*ssing me off... just wanted to know if any1 has any quick an easy solutions.. it gets worse as the car heats up and the pads seem to have plenty left on them..
Cheers,
Edited by 02_FNE
your discs may need machining, as said above if they have glazed they will make noise, using anti-break squeel spray only masks the sound untill they heat up again, with my commodore i used to get discs lightly machined every time my pads were changed.
some pads claim to be anti squeel, anti dust, but from my experience disc condition is a contributer to brakes reaction and performance.
you may also have performance pads which tend to squeal more.
if you don't use your brakes hard, try putting standard pads back in, but expect pad fade when they get really hot
hi mate if you want to stop your brakes from sqeeling file down the leading edge
I'll be the voice of reason here. . . Simple Fix = DOSEN'T EXIST!!! You really need to give a more detailed assessment of of what is happening (worse when hot! is it, lightly braking, hard braking, trail braking? etc.) and your ability to actually fix the problem (I would assume by asking this question you are not in the trade but can you handle, and own, tools?).
Then there is what discs you have and what condition they are in (lipped? etc.). What brake pads you have.
My suggestion assuming you have reasonable street pads and your discs don't have massive lips on them - Take it to a good machanic and ask them to
1, dissassemble the brake assembly and clean EVERYTHING. As in slide pins, retainer springs, ALL the shims front and back (skylines have quite a few), the pads (as in the backing where the shims go) and so on
2, deglaze your front pads by rubbing them on coarse concrete. Still the best method used.
3, #BIG NOTE# skylines have a straight edge on the bottom of there pads. This needs to have a semi moon or cresent filed out of it to match the sweep of the inner edge lip of the worn disc (1 or 2mm)
4, have the disc removed and degazed using sand paper or a biscuit wheel on both sides
5, #BIG NOTE 2# get the inner and outter lips on both sides of the disc, steel wheeled or steel biscuited as well to remove a lot of the rust and crap that builds up. And to litterally take the edge off things!
6, All contacting sufaces ( back of brake pads, both sides of ALL shims, slide pins etc.) MUST have anti-rattle grease applied (you can get it in a can)
7, reassemble and it should be sweet.
3 and 5 are the major ones to note in my opinion and from what i've seen
Hope that helps a few people.
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
