  • 3 weeks later...
Hi Laurel,
Hope you dont mind me trying to help.
Is this the same HKS turbo that you were talking about in your previous for sale thread:
"hey guys iv got a hks t04e turbo litle shaft play 450 n a set of sard 550 cc injectors for 550 pm me or call 0410661080..."
If so it maybe ideal to let prospective buyers know that it does have shaft play in this thread?????? I would hate to be the buyer then realise the turbo had shaft play.
Of course if it isnt the same one best of luck with the sale and free bump! even if it does have shaft play still not a bad price after rebuild, however it maybe beneficial to let buyers know this.
https://www.sau.com.au/forums/topic/210922-hks-t04/#findComment-3771674
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
