Well car is gettin resprayed in a few weeks and im just wondering if i want the spoiler off. The problem im having is i cant just take it off for some reason. My mates s15 spoiler came straight off when we undid the bolts but mine is stuck.
Just wonderin if it has some sort of glue??
also dose anybody have any picks of red/maroon 32's with the back spoiler off?? the more the better, will make my decision easyer.
cheers
https://www.sau.com.au/forums/topic/210968-r32-spoiler-removal/
cheers
1. there are a few bolts which you can see under the boot lid, undo those.
2. the centre part of the spoiler is held on by a big 4-way clip. this is a b*tch to get off!
3. disconnect the brake light harness
4. all that's left is double sided tape, which is inbetween the spoiler and the boot lid. make sure you don't rip the paint off or leave any hefty scratches while taking the tape off.
hope that helps :no:
Edited by dmr
geez what a hassle just to get a spoiler off. i think i will just leave it on for now. cauz i just wanted to take it off to see what it would look like. see if i liked it.
but im still looking for some pic's of some maroon 32's with no spoiler.
thanks for your replys.
Not sure how many different style spoilers are out there for the 32's, but for my one, there was only 4 bolts altogether. 2 each side. There's some sort of glue holding the spoiler down as well. You'll need a bit of force to get them off.
I seriously wouldn't recommend taking the spoiler off 'just to see how it'll look' because the glue underneath it would be a pain in the arse to clean up. THAT and what happens when you don't like the look? You'll have to go out and get more glue. hahah
Up to you, but I reckon it'll be a pain in the arse if you just wanna see how it'll look.
even if you ripped off all the glue, the bolts alone will hold the spoiler down firmly
There are two types of spoiler for the 32. There's a type A and a type B spoiler. The type B spoiler mounts at the two ends and in the middle. The type A spoiler only mounts at the two ends of the boot.
Before you unbolt the spoiler make sure you disconnect the wiring for the high centre brake light. Then once you've unbolted it, it will just lift straight off.
Edited by White GTS-T
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
