Item: ARC FMIC kit
Condition: Brand new, still packaged
Price:Price Drop $1000 + postage or best offer
To Fit: R33 GTS-t 93-98
Contact: Eli - 0401 745 977 or pm
This item is a brand new GENUINE ARC FMIC kit from japan. It arrived today and is still in all of its packaging as i only opened the box to make sure it was all there, in good condition and to take photos for this sale thread. I sold my R33 2 weeks ago so i no longer need it.
The kit uses ARC's MO73 intercooler core with a turnflow exit endtank. The advantage of using this setup is that all the piping can be run through the original holes on the passenger side of the car keeping this a very stealth and neat looking kit from inside the engine bay. It also negates the need to cut a hole in the driverside wheel well and run the "cold" pipe over the fan and radiator. On alot of the cheaper kits out there the "cold" pipe over the radiator setup can sometimes either sit too low and touch the fan which then requires trimming, or to high and fouls on the bonnet when shut. This kit has been engineered by ARC japan to be a 100% bolt on unit. Workmanship on the intercooler core looks to be 1st class.
All parts are included in this sale and if shipped, will all be packaged neatly and safely inside a plain box to reduce the risk of theft or curious eyes taking a peek inside and possibly damaging anything which insures you get the kit in 100% perfect condition.
Parts Included:
- ARC MO73 Intercooler core with turnflow endtank (470 x 260x 70)
- ARC Piping kit to suit S1 & S2 r33 GTS-t (3 pipes total)
- ARC Green High Quality Hose joiners x3
- Cyclone hose clamps x6
- Mounting Bolts
- Instruction Booklet which i havn't opened but it looks like it's in japanese :)
Installation of this kit is very straight forward. First step will be to take the front bar off and if you have enough skill to do that you will have enough skill to install the intercooler kit :yes: its that easy.
please contact me with any questions you may have,
thanks alot ELI
P.S. pics of the kit will be up tonight once i find my camera usb cable :P
Pics Done. sorry for quality, will put better ones up tommorrow when i have some light:)
and a pdf from the ARC websit showing an illustration of its basic layout
ecr33.pdf
Edited by ELI
these things are awesome....
personally dont have one (cos i'm not plannin on upgrading my turbo on my r33) but i can tell ya on my old r32 gtst i had an ARC sidemount. Just the design of them makes the world of difference.
I'm not too sure but i think the inlet is the left side and you'll notice that the air tubes are like flared out where they meet the tank... optimises flowability.
can't understand why this hasn't sold yet.
good luck with the sale anyway.
hey mate, when you mean the kits installation is straight forward, what do you mean? is it that easy? no cutting involved? no welding no nothing? i'm interested in it cuz every other kit seems to need work done, and its gonna cost to get someone to do it for me. how does it kit hang? do i have to drill bits into the chassis? or bar? does it matter what bar is used..every commen bout this kit seems to be good..but just dont know if its all true.
I got a Blitz LM which is almost the same. You may have to cut a little off your reo and move your horns. And if you may want to cut out the middle bit of your front bar which looks like a type-m style to get more air to the cooler. DIY, about 3-4hrs.
the kit uses holes that are on your car from the factory so definately no drilling is required, all bolts and mounts are also included. it comes with a booklet of instructions, i think they're in japanese but you should be able to go by illustrations to figure out what holes to use. as Far Tony said you may have to cut a little off your reo but im not 100% sure its neccessary as the core is a little smaller than your average cooler. as i said in the first post my car has been sold but it was to a friend so i might be able to get him over so i can take some photos of where to mount the cooler. can't promise anything though.
any other questions or need more pics just let me know
cheers, eli
  • 4 weeks later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
