  • Replies 745
What about the Mongrels... what did Josh say they were worth?
they are a really good tyre for what they are... and now in 33 x 12.5... they sound good... some new suspension and body blocks and emma's lux would be looking tuff...
when do you get your big rig Brocky Cutter?
Hey Actually here is another topic for this CQ Performance Thread... I was talking to Darren of 180GO fame and I asked him a few questions about brake upgrades for Clubsprints... He told me that I needed to Take off the Metal backing plates for the disc brakes... now I know this seems obvious but is this a good move for a street car... does it protect the rotor more than it matters... what about does it act like a heat sink ( draw heat from the disc) or does it trap in heat?? I think it traps heat, and I personally think if you brake a rotor you are probably doing the wrong thing in your import (eg. 4x4 competition or something)
what do you guys think?
Also he actually recommended Bendix Ultimate Pads... he said if I had the money go with Endless NA-R but otherwise Ultimates are the Go... I thought there would have been heaps of pads better than the old ultimate... but he seemed to think they were really good for the price... so maybe that is something to think about next time you are crying just thinking about the price of big name Jap brake pads.... stick with the old Bendix Ultimate!!
I'm still chasing interested parties for the trip to Brissy at the end of this month... it will be simply awsome with a few cars punting around the track... and don't think your car is to slow... I can show you some video of a stock early pintara thrashing around the track in Panda Colours... it is really open to ANYONE... JR that means your mirage to...
Actually it would be awsome to have enough cars there to have our own bracket (7 cars) on the track... all CQ motorsports fans...
Hey brocky cutter...... are you a rtuckie or sumtin.. coz my dad is a truckie. he has a Kenworth T904. Best one around!....
Wanna know why. its a RICE RIG!!!!!!!
$8000 worth of shinnie stainless steel on it.
and. umm.... Couple of blue neons. on inside and out!.like behind the front grill....
Pioneer Head unit- : Front speakers - Fusion
: Rear Speakers - Alpine
: 10" Pioneer Sub, all amped up by a little pioneer amp.
Oh and a t.v and video player
Hoo roo
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
