Sounds like a good day by you guys!
Good to see the GTR in action Jason!!
Ive got a day in lue....so I'll keep an eye out on a day coming up
Brad - seeyou at EC next sat :)
Oh, theres an EC L2S day coming up
  • Replies 163
Posted Images
Brad - seeyou at EC next sat :blink:
For sure!
Brakes bleed up today, transmission will be built tomorrow. So its all looking like it will be ready to go.
There is a few regulars going out so its shaping up to be a really good day out.
Yeah Im looking forward to it.
Haven't done a 'khana for a while (DECA/Texi) and Im back on my street tyres so I'll be out having fun - even if I have no chance and will be drifting a bit!! :whistling:
same its been ages since I was out on a decent skid pan.
Im going to use the old street tires as well and RWD to go with it. 400Kw all to the rears should be interesting to say the least.
Just need to find some rims to clear the new brakes
mine also makes over 400kw at all four wheels and on 4 year old street tyres that are hard as rocks was still blowing away he rotors i love smoking past them
I've heard quite a bit about your car, seems to be one of or maybe the only one that's very quick in NSW.. :)
So what times were you doing at OPGP?? That way all the guys doing the superbattle can have an idea of what they should be chasing (besides giant)... :rofl:
So what times were you doing at OPGP?? That way all the guys doing the superbattle can have an idea of what they should be chasing (besides giant)... :cheers:
my work shop is next door to oran park so the car has been there lots of times it can do 1.12 around full track and 47 short track on the old track at wake field on street tyres and no sway bars 105 flat the times are on nat soft we are pulling the engine out this week to do some more work gaints car looks like an animal going around the track
Fark me!!! 1:05 at Wakie on street tyres!!!! Looks like there's going to be some stiff competition at superbattle... :)
Tell me your going to go new semis for this event??!?!
Jason Bobby was chatting to you this afternoon. Ive got to arrange to drop past and pick up some sway bars this week.
After tunning my car that night at Adam's I got bored and went back for more a week or so latter.
You may remember you walked in at the end of the tune, Grey GTR fully caged with massive cams and external gates.
hi buddy how did the car go in the end i got myself an r34 gtr v spec now as well
Nice, ill drop past and have a look possibly today.
I was doing a few things to Bobby's R34 Nur yesterday when the bars came up in conversation again.
Mine has now made 440, its enough to get into trouble with, Had it at wakefield a few weeks back but broke a box and the brakes failed so was happy with 9's.
Ive since fitted F50 brembos and repairing the box today.
With my extra 100Kw and all new suspension set-up (ohlins, swaybars etc etc) I was actually slower at wakefield. Once I get the suspension working properly again it should be much faster than before. Not to mention it should stop now too.
Are you happy with the suspension Chris or is there more to be had??
Ive been using a pyrometer lattely and was seriously unaware of how uneven my tire temps actually were, for test and tune days like the L2s ones they are an excellent tool to have.
Hey Brad,
Yeah I actually use low boost which is 9 - 10psi (round 200rwkw) at the track just to keep things a bit, well, looked after as my car and motor are basically stock!
Suspension is ok I guess? I did a day at OP North on sat, only understeered in the wet/damp parts, but sat pretty well when dried out. Didnt open wheel this time either but I just feel I need a bit more front camber. Duncan told me about that temp guage thingy for tyres! Yeah would be good to use one!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
