Skylines Australia MEETS Nissan Silvia.com Cruise - Friday 25th July (This friday)
  • Replies 62
yeah this 200sx might turn up..have no idea who called it 'fully sick'..certainly wasn't me.. cause it's not finished..
it's gotta be lowered yet..
but other then that..it's damn nice.. c ya all there..
Ya gotta come up 2 me and say hello..wouldn't mind getting to know some of ya..
It's had a few things done to it...
Strengthened gearbox and clutch, 17inch chrome rims, full exhaust system all the way through, custom intercooler , tis huge!!
Full bodykit, hybrid wing. boost switch..turbo timer, all that stuff. Had to disconnect boost gauge cause of inspection for SA plates..gotta put back on.
Got da sports steering wheel as every1 does..basically a BOV but it's actually from the wastegate..ul hear it..sick noise.
Has reasonable size speakers in the back, which currently aren't connected to CD player as AMP has been taken out. Gotta fix it.
Just needs to be dumped..but am having enough trouble driving over bumps and stuff with front spoiler.. so might put it off for a while..
for a chicks car..tis not bad..is a bit of comp on da road..but yeah.
Correction - now TIMMMAYYY, the quote wasn't "fully sick" it was "Tis a wicked car" if you refer to a past thread!! :rofl:
I think you'll find pics here...
http://www.skylinesaustralia.com/forums/sh...25&pagenumber=1
the 4dr shall be there
changing plugs this arvo and getting a dogy manual boost controller also might as well up the boost a bit more
is this gunna be crazy p platers in the hills in the non turb silvias thing ????
Yes, 8 pages of maps and not written directions...i.e Turn left here then turn right here... Should be a good cruise if people follow the people with maps. Or follow JSPEC OR S15. Following any other cars will probably get you lost...through the hills.
Yes yes.. Ben from the Nissan Silvia crew has some serious mapping skills when it comes to cruises.
So we'll have him to thank.
See you all tonight.. If there is anyone that I have left out about the meet spot, pm me or somthin!
The cruise.. well the parts i went on was pretty tuff. Jaffa sounds awesome, and john, piss those re540's off and get some shitty tyres on the GTR for some 4wheel burnout/launches.
Did anyone get their ass busted at the Boat Ramp?I was drivin home and saw 4 or 5 people goin the other way about 15 minutes after I'd left The Airport Car Park n was wonderin wat was goin on.
Well BOOSTD and I pretty much lost everyone after the Bunnings saga but caught up with the cruise at Big W.
The b/f whinged so much about not knowing anyone and wouldn't get out of the car so I got the s%& and went home!!
Spewing I missed the action!! :D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
