as said i got redline shockproof lightweight put in my 32GTR gearbox today and i had bought 1 gallon = 3.75 litres or whatever it is, and it wasnt enough it still needs almost another litre... whats the go? i read on here from loads of other people that 1 gallon would be more then enough?
any help would be great
Cheers,
Corey
1 gallon is 4.5L
as long as the car is level, all you need to do is keep filling it 'till it starts to come out of the plug hole. just add normal g.b oil if ur out of Redline- it blends anyway
1 gallon is 4.5L
Wrong.. I gallon is 3.78litres
check google...
Who's gallon? The Seppos have a different (lesser) amount in their gallons than the empire does.
1 US gallon equals 3.785 litres.
1 Imperial gallon equals 4.546 litres.
well seeing as we are talking about Redline.. which is a US product... and the fact that it states 3.78litres on the bottle... im going with 3.78
Cheers,
Corey
There really is no set amount seeing as how you may have been empty when filling anything I always grab more then needed. You just fill till it seeps out then you know your good...
I just did all my fluids too.. 2 bottles of royal purple in each diff, and 2 bottles of Automatic Transmission Fluid in the transfer case as reccomended by Nissan... Shifts smoother then ever...
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
