Hi, Has anyone had much experience with diagnosing creaky suspension. I have noticed the when traveling over bumps, in and out of the driveway and some cornering there is a creaky noise coming from the front suspension. Im not sure if it is from the shockers, swaybar bushes are the control arm bushes.
Under braking / acceleration there doesnt seem to be any noises which lead me to believe that the problem is not control arm bushes (Or maybe im just hoping this), From what i can tell could it be the swaybar bushes ? they seem a little deformed and worn but not too bad or do shockers make this type of noise also ?
The car has done 60k and everything is original so its probably about time that some parts need replacing.
Any ideas of what I should do ?? Remove the sway bar and see what happens or can I take the car some where do a propped diagnosis ? Let me know what experiences you have had
regards
Dan
https://www.sau.com.au/forums/topic/211280-m35-creaky-suspension/
regards
Dan
I have noticed it, sounds like something is loose, I was told it is common but poses no safety issues......
I know this sounds crazy.....but take it to pedders and get their $14 check. Their job is to find everything possible wrong so they can make a sale so they actually do a pretty thorough job. and when they are done get them to actually show you the problems on the hoist.
but don't get them to actually fix it of course
I like your way of thinking.........
Thats what I was thinking of doing Cheers
what on earth is a camber pin? bolt through a bush for a control arm? or didn't they really explain it?
camber is not adjustable except for a tiny bit at the rear so I have nfi what they are talking about
I had a knocking noise and that was down to worn bushes but I get a creaking noise and that may be on the shocks so I will investigate further.
Thanks, Did you get replacement bushes for the car ?, Which ones did you need to replace ?, How much ?
Did you replace the swaybar bushes at the same time ?
Edited by danwatt
yeah I replaced the swaybar bushes and the others were down around the bottom of the suspension tower
work carried out by Autolign here in Auckland for $NZ 461.25 but I paid $200 approx extra for parts ex Nissan Japan
Autolign carries sway bar bushes for this car as these commonly go
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
