  • Replies 58
do you have the coil pack loom at all bud.?
just pm me back please.
cheers
Allan.M
Hiya, pm sent
how hard was the "bump" im after the factory smic piping, do you if the piping on S1 and S2 are the same?
hey, i'm 99% sure the piping was not damaged but i'll check tomorrow to make sure. Piping is the same between S1 and S2
Got the fuel cap?
yep $10, pm me if interested
Hey mate how much for the headlight? Is it all in working order, and wiring? If you could let me know asap.
Cheers
hiya, i'm looking for somewhere near $180 for it, in working order apart from the broken mount where it links with the grill. Can include wiring if needed. pm sent
you got pm reguarding motor
Pm replied
https://www.sau.com.au/forums/topic/211354-sold/page/2/#findComment-3742663
hi don't know what happened but i haven't received the pm you sent me do you mind resending it to me please.
cheers
Allan.M
resent pm :cheers:
Money sent for the rear fuse box!!!!!
Hope to get it asp please!
Thanks!
cheers, money received, will post it asap.
hi mate im after the fuse box cover, but would it fit a r33 series II 1996 turbo? also how would i pay for the item and how would i recieve it? thanks joe
Pm sent
whats the condition on the larger dash surround w/ clock, hazards etc
looks good in the pic.... does it have any colour fade etc??
it's in good nick, PM sent!
hey im after a drivers side mirror and black rubber seal around drivers side windows if u have available.
could u PM me ur price with shipping to Melb 3037 thanx
Pm sent
I'm after the passenger side door trim, what condition is it in and what times during the week would I be able to pick up?
Sorry mate missed your PM before, pm sent
https://www.sau.com.au/forums/topic/211354-sold/page/2/#findComment-3748221
Hey,
how's the RH front guard?
How much? and would you mind shipping interstate?
if ok, any chance of a pic..
Thanks mate!
Sorry mate I wouldnt want to freight any of the guards cos theyre quite fragile, they would likely be damaged
All other pms replied!
https://www.sau.com.au/forums/topic/211354-sold/page/2/#findComment-3767801
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
