  • Replies 58
hey bud,
can i buy the whole lot of the seat belts with brackets n bolts, both front & rear.
i live in Cairns, so if u dont mind having to post i'm happy to pay:)
cheers Daniel.
p.s can u pm me ur number
PM sent
PM sent
Pm replied
Any 5 stud wheels??
Just have 1 pair of 5 spoke 17's in silver. Can get pics if you're interested
List updated, few prices dropped :)
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3774556
pm sent about that cat
Pm replied
still got RHS headlight?
Sorry mate it's sold to J'z-R33 :P
Yeah can you send me some pics please? How much you after for the pair?
Thanks.
Heres a pic:
Pm sent
hey mate
if you don't mind selling the Snorkel alone with no airbox, i would be interested :rofl:
PM when you get the chance with a price :P
At the monent just looking to sell them together, I'll let ya know if i decide to seperate
any chance you have the unleaded fuel restrictor neck?
Kent
Is this what you're after?
If so, yep. $40
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3779027
Hey guys
picked up another R33 Skyline for wrecking. It's had a knock on the front left so the bonnet, left guard, headlight, etc etc are gone
Rb25det turbo engine- has 93000 k's. Has had new Gates timing belt installed @ 63,000ks..
Compression tested this engine, good results accross all cyl: 154 155 153 154 155 154psi
Complete motor, wiring loom, S2 turbo/lines Sold
5sp Manual conversion kit (5sp box, clutch, flywheel, tailshaft, pedals, clutch master/slave cyl & all lines) -$1900ono
everything ya need to convert an auto to manual!
Series 2 AFM (pink sticker) - $120
window washer bottle - $20
radiator overflow bottle - $20
Engine bay fuse box cover - $30
3" dump/front pipe combo $100 PICKUP!
3" Catco cat, 487CFM - $80
3" catback exhaust - $160
Drivers side S2 foglight/indicator Sold
Aircon compressor $120
coilpack cover $40
standard airbox + snorkel $90
Brakes/Suspension bits:
Power steering rack - $125
castor rods - $80 pair
TEIN HA front coilovers - pair $350 Sold
stock rear shocks/lowered springs - $150 pair Sold
front rotors, top condition - $70 pair
front calipers - $300 pair
rear rotors top condition
rear calipers - sold
front hubs $80 each
rear 5 stud hubs - $160 pair
front upper control arms- $60 each
rear lower control arms- $70 each
rear upper arms - $50 each side
handbrake drum assembly + cables - $220 pair
stock viscous ABS diff - $250
driveshafts/halfshafts - $80 pair
hicas rack - $30
front swaybar - $20
rear swaybar - $20
rear cradle - $50
Exterior bits:
rear Skyline fascia, white - $40
bootlid, no spoiler, shaved boot lock - $150
fuel flap lid $15
Interior bits:
Instrument cluster - manual with 93000ks - $100 Sold pending payment
S2 airbag steering wheel, $225 ono
dash gear surround w/ leather boot and cig lighter - $50 Sold pending payment
climate control unit, as new condition $60
larger dash surround w/ clock, hazards etc - $100
Series 1 door trims - $60 each side
drivers side window motor -
handbrake boot, immaculate - $25
stereo mounting brackets - $25 pair
series 2 front seats in top nick - $200 pair
series 2 rear seats $80
glovebox - $30
floor carpet $80
centre console lid, perfect nick $40
seatbelts & buckles + bolts full set - $100ono
steering wheel surround plastics - $30
both headlight & indicator stalks - $40
parcel shelf - $40
complete boot interior (except piece that covers battery), good condition - $80
electric aerial $50
rear wiper motor - $50
PM for anything not listed!
Pickup welcome, or I can post anything as long as its not too big for auspost
Located in Sydney, near rockdale
cheers :(
hey im interested in your stearing column plastics and was also wondering if you the drivers side window switches at all
thanks Matt
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3789533
How low are you willing to go on the price for the front r33 calibers?
Pm sent
thanks Matt
Pm sent!
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3796714
Sorry to anyone who tried to msg me last night but couldnt, my pm box was full
hey mate do you have the passenger side door trim? also the latch goes into lock the door (attached to outer door) also ur location?
Cheers.
Yep, PM sent
How much for the relays from the interior fuse box, the 45amp fuse from the boot for the blower motor and the fan/blower motor. Thanks
Pm sent!
just wondering if you still have he front and rear seats, and if possible all the door and rear side trims also.
you wouldnt have the standard computer would you?
Yep i still have the seats and door/side trims, sorry no ECU though. PM sent
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3799793
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
