so as most people know i was in an accident in november last year
i got the car back a little more then a month ago
on thursday night
11 pm
im driving down chapel street
in heavy heavy traffic
the car infront slows to a stop
i slow to a stop
i look in my rear view and i think wow that car isnt gonna stop
BANG
brand new clk 500 convertible rear ends me
i went apeshit at first then apologised to the guy saying sorry for loosing my cool
he said sorry and admitted he wasnt paying attention and takes the full blame
and half of chapel street had a good laugh
now my cars gonna be in another ********* shop again
anyone got estimates on how much work this is
im hoping no more then 2 weeks
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/
that doesnt look too bad
i had a hit like that ages ago, was gone for 1 week
1 week is reasonable, they might have to pull the boot out a bit
make sure you check if it aligns up properly when u get it back
and also make sure the boot opens / closes properly
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738790
That sucks!
Get it checked properly, you may need:
- rear bar skin (S1 and S2 are the same)
- rear bar reo
- rear tail lights (if mounts are broken or rear plastic cracked)
- rear "SKYLINE" fascia (if mounts are broken)
- repairs to rear quarters, boot lid, and tail gate.
May take time and a bit of work to do it properly. If it's not done right you'll keep having on going issues with water in your tail light indicators.
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738797
think youd be a lil more careful driving such a nice merc
these are good tips, thanks everyone. i dont really have any idea :S
im hoping to take it to "DT Panels"
they have been recommended from a friend.
hopefully they have easy access to all these parts
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738800
My call is as follows
Rear bar
Rear bar rio
Boot floor
Rear panel
Skyline fascia
Skyline badge
Trust me, I know about these bloody rear enders.
Will be off the road for about 2 week once all the parts are in stock.
BASS OUT
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738831
Exactly the same thing, happened to me but I was at the lights!
My quote was
TOTAL $3,346.00
NOTES :
THIS QUOTE IS FOR VISUAL DAMAGE ONLY
FURTHER DAMAGE MAY BE FOUND ON DISMANTLE
PARTS PRICES SUBJECT TO CHANGE!
It looks almost exactly the same but just imagine, your big dent on the right!
Such a horrible feeling!
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3741570
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
