Well today I went to the car and the car wont start. When you flick it to start you can hear the fuel pump pumping but no starter motor. Everything else seems to be working as per usual.
I checked the fuses on the drivers side kick panel and all was in order.
I checked the battery as that seemed fine, The radio / windows and everything work fine.
I disconnected the battery for 1h to see if that had anything to do with it.
Its got me stumped. I thought it could be the imobiliser but that seems to be ok too. I couldnt check the integrity of the immobiliser connections into the cars harness as I had no idea what I was looking at.
The only thing that seems different to usual is that when you move the shifter to reverse there is no revers sound on no revers lights. ( I noticed this when I tried to start it N)
Any idea why there would be no reverse lights or signal ?. Is there a fuse for the Lights that I cant find but surely this wouldnt stop the car from starting ??
Please help me as I am stranded.
https://www.sau.com.au/forums/topic/211724-my-m35-stagea-will-not-start/
I do Ill will check that ? Thanks.
When the ignition is on and where the normal gear indication is there is nothing to say what gear it is in.
Does anyone with M35 have the sear selection when the ignition is on "ON" mine saays nothing.
Hi Dan
Yes my M35 does have an indicator at the bottom of the speedo. It comes on when the ignition is on and show P, R, N etc. Have you had any work done on the car lately? New sound system etc. There is a thread on removing the centre console around the gear selector. It may show you a plug that has not been put together correctly.
Good luck
murray
Hi Dan
Good luck
murray
Sounds like the right idea. Sounds like the computer is not picking up the gear selector and will not let the car start unless it is in D.
Cheers
Andy
Edited by andy65b
Hi Dan
Good luck
murray
Thanks Murray, I have had the contre console out in the past and it is possible that there is something wrong there, I will check the connections tomorrow and try to determine if there is something not right.
It seems weard to me that there is an issue now when it had beed working fine for some time.
yeah, no gear signal getting through to ECU, like Murray said, check harnesses. Bad connection or something left off. Also check connections at Auto ECU, drivers kick panel on C34s.
On the drivers kick panel on the M35 there is the fuses as well as some control unit and alot of harness. Whats on the C34s ? Should I unplug the plus and just make sure everything is connected secure ?
I think it would be more like the centre console as I have had this out in the past.
I appreciate your assistance.
like the others, im betting that it is the switch from our shifter not telling the ECU what gear the car is in, thus not letting it start, as a safety measure. In which case im pretty sure that that would not be fused due to it wold only send a really low amperage/low voltage signal.
sounds same as C34, Auto ecu with a large harness, probably start unplugging and replugging all the plugs on centre console first though. just test as you go.
Well everything looks in order in the centre console, The only plugs that get disturbed when removing the console are the heated seats, 4WD syncro, hazards and shifter light. The shifter mechanism has only 1 main plug and this seems good.
The AUTO ecu on the other side kick panel has a hundreds of wires going to it and about 6 connectors. Seems like a lot of wires how would you know where to start.
Did you drive it after you had centre console out ? or something that has happened well after you did any mods ?
The Auto ECU should have fused power, check for power there, the 12V wire or wires should stand out from the rest.
I had been driving I for a while, But hopefull I may have found the problem as I have located another set of fuses and relays that I will have to check tonight. Im keeping my fingers cross as this problem is driving me insane.
Well I finally solved the problem , I was reading through some V35 documentation when it referenced another set of fuses and relays that are not that obvious on initial inspection. The fuse box is located on the passenger side firewall right in the corner. To see the Fuse box you need to remove the battery cover & surround as well as the black plastic window trim.
A simple fuse was all the problem see picture of fuse location.
good to hear, big relief Im sure, any idea what caused it though ?
Yea I know exactly what caused it, When they did the compliance and installed the rear child restraints. (Mine are in the top of rear or the cabin where the tailgate is mounted) and one of the bolts had damaged the rear tailgate harness. It wasnt until I went looking for a reverse light signal for my camera and the tuner that it failed and rendered the car useless.
Basicall if you short the reverse signal to earth you blow the fuse and the car wont start.
Im glad this didnt happen somewhere else away from home or else I would have been stranded with no clue and to make things worse its hard to get the towed with the body kit as there are no accessible tow points.
Now I am trying to work out how to route the video signal through the tailgate to finish the camera install.
Cheers for you help and support.
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 😏
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
    • I saw a car just like this stopping at Harvest for coffee this morning
    • Factory Dash Lamps...Half the speedo was dark...T10 3 Watt Park Lamps...T10 5 Watt Tachometer Chip/IC...Tach would randomly go crazy or stop, replacing  capacitors and re-soldering the chip would work for a week or so but it would always fail again...AN8352UBK (Buy on ebay AU) Heater/Air Con Control Button Lamps...Grain of Wheat Bulb 12V...Tried LED's they fail after a month or so(even with current limiting resistors)
