Well today I went to the car and the car wont start. When you flick it to start you can hear the fuel pump pumping but no starter motor. Everything else seems to be working as per usual.
I checked the fuses on the drivers side kick panel and all was in order.
I checked the battery as that seemed fine, The radio / windows and everything work fine.
I disconnected the battery for 1h to see if that had anything to do with it.
Its got me stumped. I thought it could be the imobiliser but that seems to be ok too. I couldnt check the integrity of the immobiliser connections into the cars harness as I had no idea what I was looking at.
The only thing that seems different to usual is that when you move the shifter to reverse there is no revers sound on no revers lights. ( I noticed this when I tried to start it N)
Any idea why there would be no reverse lights or signal ?. Is there a fuse for the Lights that I cant find but surely this wouldnt stop the car from starting ??
Please help me as I am stranded.
https://www.sau.com.au/forums/topic/211724-my-m35-stagea-will-not-start/
I do Ill will check that ? Thanks.
When the ignition is on and where the normal gear indication is there is nothing to say what gear it is in.
Does anyone with M35 have the sear selection when the ignition is on "ON" mine saays nothing.
Hi Dan
Yes my M35 does have an indicator at the bottom of the speedo. It comes on when the ignition is on and show P, R, N etc. Have you had any work done on the car lately? New sound system etc. There is a thread on removing the centre console around the gear selector. It may show you a plug that has not been put together correctly.
Good luck
murray
Hi Dan
Good luck
murray
Sounds like the right idea. Sounds like the computer is not picking up the gear selector and will not let the car start unless it is in D.
Cheers
Andy
Edited by andy65b
Hi Dan
Good luck
murray
Thanks Murray, I have had the contre console out in the past and it is possible that there is something wrong there, I will check the connections tomorrow and try to determine if there is something not right.
It seems weard to me that there is an issue now when it had beed working fine for some time.
yeah, no gear signal getting through to ECU, like Murray said, check harnesses. Bad connection or something left off. Also check connections at Auto ECU, drivers kick panel on C34s.
On the drivers kick panel on the M35 there is the fuses as well as some control unit and alot of harness. Whats on the C34s ? Should I unplug the plus and just make sure everything is connected secure ?
I think it would be more like the centre console as I have had this out in the past.
I appreciate your assistance.
like the others, im betting that it is the switch from our shifter not telling the ECU what gear the car is in, thus not letting it start, as a safety measure. In which case im pretty sure that that would not be fused due to it wold only send a really low amperage/low voltage signal.
sounds same as C34, Auto ecu with a large harness, probably start unplugging and replugging all the plugs on centre console first though. just test as you go.
Well everything looks in order in the centre console, The only plugs that get disturbed when removing the console are the heated seats, 4WD syncro, hazards and shifter light. The shifter mechanism has only 1 main plug and this seems good.
The AUTO ecu on the other side kick panel has a hundreds of wires going to it and about 6 connectors. Seems like a lot of wires how would you know where to start.
Did you drive it after you had centre console out ? or something that has happened well after you did any mods ?
The Auto ECU should have fused power, check for power there, the 12V wire or wires should stand out from the rest.
I had been driving I for a while, But hopefull I may have found the problem as I have located another set of fuses and relays that I will have to check tonight. Im keeping my fingers cross as this problem is driving me insane.
Well I finally solved the problem , I was reading through some V35 documentation when it referenced another set of fuses and relays that are not that obvious on initial inspection. The fuse box is located on the passenger side firewall right in the corner. To see the Fuse box you need to remove the battery cover & surround as well as the black plastic window trim.
A simple fuse was all the problem see picture of fuse location.
good to hear, big relief Im sure, any idea what caused it though ?
Yea I know exactly what caused it, When they did the compliance and installed the rear child restraints. (Mine are in the top of rear or the cabin where the tailgate is mounted) and one of the bolts had damaged the rear tailgate harness. It wasnt until I went looking for a reverse light signal for my camera and the tuner that it failed and rendered the car useless.
Basicall if you short the reverse signal to earth you blow the fuse and the car wont start.
Im glad this didnt happen somewhere else away from home or else I would have been stranded with no clue and to make things worse its hard to get the towed with the body kit as there are no accessible tow points.
Now I am trying to work out how to route the video signal through the tailgate to finish the camera install.
Cheers for you help and support.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
