  • Replies 100
maybe throw up a rough price for general service (oil/filter/plugs), then maybe a diff oil/trans oil change, to things like links/bushes/suspension just to give people an idea. Seems like timing belts are your thing :D, rough price to get one changed? maybe even turbo swaps/manifold swaps, not everyone needs work right now, but if something where to come up then its always a good reference.
will keep you in mind, if im unable to do it myself :ban:
ok then .
quotes.
timing belts full kits inc,water pump,bearings,fresh coolant,belt,seals,checkover car,from 700$.
service oil and checkover car from 65 inc mineral oil and filter.
direct bolt on turbos for rb's from 250$
full service inc,gearbox,check diff,,engine,brake,and complete check pver from 140$inc parts and labour .
really if you can find better on these prices i would say go for it as they are not much for labour.
cheers,
ps. had plenty of happy customers ,
hope every one is happy with the service as i am pretty sure that they are.
Just to give John another :thumbsup: - he did the water pump, cam belt, tensioner, idler, air/powersteer/alternator belts on my 32 GTR. He did great work and gave me a good price. It was also cool to be able to hang around and chat about a few other aspects of the car. Definitely recommended.
i don't know john so i can't say if he's good or not... he sounds decent
one thing that will be a worry is that he doesn't have public liability (???)
this could be an issue if you get a dickhead customer who screams 'you broke my car!'
i need an auto electrician... i want a relay or solenoid installed in my car as it has hot start problems?
can you do this? i prefer not to replace the starter as it's ok otherwise
just engine with no box or complete car ,
as i have to do this in my driveway and it is hard with no hoist it would not be worth it as you would be able to get any shop with even a bit of gtr knowledge would probably be able to do it cheaper.unless its just engine it would not be woth it for me or you to do it.
sorry but im just laying it out straight.
cheers
what do you mean hot start probs. as in the car wont start again once its warmed up?
if this is the case its prob a faulty starter relay in that case just needs a replacement with a new one if thats not it i would need to have a look at it and yeah i can probably fix it !
ps. its good to see someone look from the mechanics p.o.v for once on the liability factor as that stuff does happen but i am not stupid and if something goes wrong thats my fault i warrant all the work i do.
cheers
lol mate i was like you , doing little jobs at home but now ive got all the specialty tools
i do engine rebuilds , gbox rebuilds , turbo/engine conversions e.t.c anything really,but rarely do i get ppl for service's
i specialize in SR's RB's and EJ's
current job im doing
http://img139.imageshack.us/my.php?image=imgp1175kp3.jpg
So if any one has jobs that johns not interested in doing
give me a call 0406209351
GL john
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
