Its A Hard Life Part 2
  • Replies 47
Guest INASNT
akeenan
i am near a town called Tully, which has the highest rainfall in Australia every year, and when it rains its farkin rails hard and for ages, but the wet season is near christmas time so i wont be around them.
We are doing something similiar to high flowing a turbo, replacing the turbine runners with bigger runners, new shafts etc.
Guest INASNT
Originally posted by nismoR34
That looks like its magnetically driven, is it?
Or is it electrically charged?
its a hydro electric turbine. The 2 big wheels on the ousides get driven by flowing water which flows in from the adjoining gorge which is 400m above the inlet valve. The wheels spin at 600rpm which produces 12,500BHP to the stator which inturn creates electrical power which is transfered to the transformer system and then into the main power grid.
There are 4 of these units which we are upgrading.
Nice :D
Would be a fair bit of lag though I imagine :D but once they're churning YEE HAA :whip:
The shaft in the centre looks very similar to that which drives the platter on a Technics 1200 [turntable] which is magnetically operated, thats why I was asking...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
