Went out to Oran Park today took some action shoots.
Please let me know what you think :thumbsup: and i hope you like :woot:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
The rest of the images can be found here:
http://www.flickr.com/photos/matthewmead/s...57604229169405/
and can be viewed in a slideshow here:
http://www.flickr.com/photos/matthewmead/s...229169405/show/
hope you like
https://www.sau.com.au/forums/topic/211809-initial-drift-oran-park-gp-240308/
Very nice pictures, number 16 is sweet- just the right amount of blur to capture the moment with out losing detail in the car.
What camera are you using?
I was using a Fugi S5600 but have just bought a Nikon D80 :banana:
this thread should say 56k beware but other than that the pics are awsome! love that sideways 31
Great shots by the way and I to would like to know what weapon youre using...
Edited by m3gtr
