Make: Nissan
Model: Skyline
Milage: 160000
Transmission: Man
Colour: White
Complied? Yes
RWC supplied? Yes
Currently registered? Yes, Till March 2009
Price: $12,400 ono
Contact: 0438166809
Comments / Modifications:
- Custom 600 x 300 fmic
- Apexi air filter
- Turbosmart Dual-stage boost controller
- Apexi S-AFC
- 3" Exhaust Cat-back
- HKS Fully Adjustable suspension
- AVS 16" wheels
Exterior:
- Full body kit (Don't know exactly what it's called been told GTR, 400R, Bomex... you decide from the pics).
- GTR Adjustable rear wing
- Very clean body
Interior:
- Newish MP3 headunit
- Decend sound system (Kenwood amp, pioneer speakers)
- Nismo gear knob
- Boost Guage
- Apexi turbo timer
- Alarm with keyless entry & immobiliser.
I'm the first owner and had it for over 5 years now and never actually tested the full potential (never been on race track). Very clean and serviced at Amberly Autos every 5000k's. Had it dyno'ed at 200rwkw @ 12psi.
Reason for selling is because I've got a V35 so wouldn't be interested in swaps either.
Images:
post-501-1206419661_thumb.jpg post-501-1206419720_thumb.jpg post-501-1206419767_thumb.jpg post-501-1206419804_thumb.jpg
https://www.sau.com.au/forums/topic/211900-fs-r33-gtst-1995-manual/
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
