hey guys just reciently my clutch has started to stick and when i hold it down for more than a couple of seconds it stays there....what is wrong with it???? would it just need some WD-40 or do you think the clutch fluid need to go? or there is a blockage in the master cylinder/ lines?
can some one please help me.....
Cheers,
Justin Murphy
https://www.sau.com.au/forums/topic/212067-r32-clutch-problem/
he guys thatnx for all the help it was the master cylinder after all.....pft and my mate wanted us to drop the gearbox to check the pressure plate.....haha what a mission that would have been.
I would still change the slave its inexpensive and easy to do. 2 bolts underneath the tranny removed it relive pressure from the nipple take it off with a open ended crecent wrench. Replace with new one bleed line and be safe for a long time... I just do stuff like that to prevent future issues... Its like the water pump and timing belt theory do them together...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
