I have an R32 that is running a lean fuel mixture on 16psi is there anyway to fix this problem without remapping coz i cant afford that at the moment and ive been told my Veilside computer cant be remapped anyway.It was pinging at 16 due to this so it is currently running 14. Also let me no if anyone has any rear tein struts they want to get rid of
https://www.sau.com.au/forums/topic/21208-tuning-my-r32-and-tein-struts/
If its got a stock fuel pump I'd replace that or at least get it checked to to if its running out of pressure at high rpm. I gather the Veilside ECU would be programmed for jap fuel, so perhaps get hold of some toluene and mix up some high octane juice?
Or just keep it at 14psi?
Have you had the car on a dyno yet to check the AF ratios.
If you are leaning out only at higher boost, perhaps look at a rising rate fuel pressure reg. Otherwise an adjustable would do the trick. Eitherways it wouldnt hurt to upgrade your fuel pump.
If your car has been tuned for higher octane, another option may be to just pull some timing.
but I highly recommend you get the car on a dyno first, as this will tell you alot more about what is going on
just some thoughts
I was gonna say I think Jap fuel is 104 ron .... either way it is tons higher ron than the shite fuel we get here .... so if your ECU is tuned to Jap fuel you'd wanna get it remapped ASAP b4 u blow a motor.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
