Hey all,
Just thought I'd share a few photos of my cars new rims. I wanted some cheap rims to last me for a few months until I sell the car, so when I found these for $800 of this forum, I was happy to have them. I need to lower the car now, so that'll be the next thing, but let me know what you think. I'm going to get them powder coated soon, so I'm open for suggetions as to colours.
Stock
Edited by NA_Goodness
https://www.sau.com.au/forums/topic/212185-my-baby-has-new-shoes/
they look good mate, but only 4 stud? i only know of skylines to have 5 stud
Factory NA's came with 4 studs..
On its arse.. it needs it..
I like it white..
Gunmetle grey looks very good an silver cars too!..
Could take a risk and go bronze?.. that wouldnt be too bad..
Block goes with everything..
Yeh, I'm scared to go around corners, becaue the centre on gravity is like a 4WD!! And yes, I need to wash them, but I was so excited to get them that I just wanted 2 get them on.
Big thanks to Fei Sti Rex (Andrew) for finding them, AND going to get them for me! Thanx man, I owe you big time now!! And Chunda, thanks for doing the 5-stud conversion!! :laugh:
I'm not sure if I want to paint the rims now! It off-sets the car nicely. I was thinking metalic gun metal grey. Something dark, but not black. I'll do some photoshopping and see how me go.
Next up is the new exhaust and cat, then lower it. Maybe a body kit and fibreglass bonnet? Dunno yet. Damn Andrew!! You have put too many ideas into my head!!
It needs to be dumped on its arse, the 4WD height probs doesnt help. It does look small, but i think when its dumped it will look bigger. Any ideas on cheap kits? I was thinking Trust front bar, with VIVA Type 3 side skirts and rear bar.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
