My car really struggles in the morning. I'll start her up and head slowly down the street, and at about 3000rpm she starts stuttering. When I got to the highway I couldn't get passed about 90km (in fifth gear) before she starts struggling. It is normal to be this bad? When she's warmed up she runs great, but these cold mornings worry me.
https://www.sau.com.au/forums/topic/212196-cold-starts/
I don't know if my ECU is stock or not. It seems there is another problem involved, it is only enhanced when the car is cold. I had the same problem a few weeks back where my muffler had imploded and we thought all the shit jammed in the muffler was restricting the airflow. Had the muffler replaced, car was running great, but now it's starting again. When totally warmed up (I took her for a long drive tonight) she starts choking at around 5-6 thousand rpm.
Before I had the muffler replaced I had my mechanic look it over, I don't think he did any serious inspection, but he definitely ran tests on all the electronics and said everything was fine. I guess I'll give him a call again tomorrow. Could it be that it was my front (is that what they're called) muffler is f**ked too, and that the shit we pulled out of the rear (steel mesh) was originally from the front, and now it's just building up again?
Thanks.
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3751882
lol.. Yeah.. Its a stock NA 6cyl. Its going to do that while your rev the chops off it.
Id say Reset the ECU first..
Then go see..
I have a rattle in my resonator box on my NISMO cat back.. does go away once the engine is warm (similar to what your experiencing) but it doesn't and shouldn't hinder performance..
P.S its not good to be driving your car hard when cold either..
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3752372
mine has a similar issue as well..
when i start it up after leaving it overnight or after more then 30minutes, its struggles to start unless i step on the accelerator to give it some help..
if i dont step on the accelerator, it just cracks, starts up for a split second and turns off
but if i just stopped driving, turn it off and start it again 5-10mins later it starts up fine, what could my issue be??
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3752565
I have the same issue. Advice would be good!
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3752741
I had a similar Issue after I did my RB20 to RB25 conversion..
This may not work on 33's and may not work on Stock NA's.. but I had something called a FPCM - fuel pump control modeul. I re-wired the circuit around ti so that it wasn't in use. I did it because I Had a look at the R32 Rb25DE fuel pump wiring diagram and then compaired this to the R32 Rb20DET and it was not present in the DE diagram.
Alturnatively.. Cheak AFM/reset ECU/TPS/Injectors.. theres a world of causes to "hard starts".. If you can get your hands ahold of a Nissan workshop manual it can help diagnose the problem
Edited by GTS4WD
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3753380
Then go see..
My rev limiter is at 7000rpm, I've gone beyond 6000rpm in the past with no trouble.
I don't drive hard when she's cold either, like I said the car struggles at only 3000rpm, that's about the point I normally change gears.
How do you reset the ECU anyway?
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3753616
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
