Hey guys,
I saw this at JB Hi Fi the other day... it is exactly what ur after if u want a PROPER steering wheel setup for a console.
Check out this link - http://www.itech.com.au/products/11965_LOG...FOR_PC_PS1.aspx
Its the first steering wheel ive seen that ISNT made of plastic and has 2 full locks just like a real car!! I'm sounding like a big gamer geek now but im just excited as im buying an xbox with forza this week lol.
Anyway im thinking of running head first into a wall because from what i can see its only suitable for PC and PS3!
Anyone have any knowledge on this???
https://www.sau.com.au/forums/topic/212219-g25-logitech-steering-wheel/
woah!! i bought my G25 for $340
LOVE IT!!! best games for it is Test Drive Unlimited and RFactor. uses the H-shifter and clutch adn EVERYTHING
you can even stall it! its soooo COOL
by the way, i use it on PC and PS2. yet to try it on PS3 but cant wait for gt5p
but yeh, it wont work on xbox
a seller on ebay sells the G25 steering wheel sets every 7 or so hours, i just bought one for $250 inc postage, looked through and some sold for under $200.
Much better then the $400 at EB
Edited by Baconer
Well once I have now got Prologue and have had a G25 for ages now so I guess I will find out how it goes with the PS3. It goes nicely with the GT Prologue demo but no clutch support. From what I hear the real Prologue (downloading updates for it now) supports the clutch.
Triptych can you pm me letting me know if the clutch works after u give it a shot. I'm installing the update now too hehe. Gettin the wheel 2moro though..
EDIT: FFS Error occurred durin update at like 95%. :@
Edited by Magic
Hang on, so Gran Turismo 5 has a clutch????
Are you guys telling me i can fan the clutch mid way through a bend in say 3rd gear? lol :)
Is there a button for the clutch using the normal controller????
Yeah the clutch works fine and it is needed to change gears once enabled. On the G25 the buttons located on the Shifter unit act the same as controller buttons. So if you look above the D-Pad you will see 4 buttons (not the red ones below it) and if you know you PS controller well those 4 buttons are the same for square, X, Triangle and Circle.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
