A friend of mine has a r32 GTST with a 3inch exhaust, mines ecu, running 10psi and a few other minor engine mods. He is experiencing a problem where under acceleration in 4th gear the clutch seems to slip. I have driven a fair few cars with slipping clutches in my time but generally they will slip in the lower gears moreso than in the higher gears. This car only seems to do it in 4th and occasionaly 3rd. The problem is intermittent as well and does not occur all the time.
If a clutch is the problem does anyone have any advice on a suitable clutch for someone with the above mods and someone who does drive the car quite hard occasionally. The guy doesnt want to spend to much on a clutch. (a $2000 clutch is way out of the question).
Can anyone tell me some prices/part numbers for the respective clutches available for an r32 gtst?
https://www.sau.com.au/forums/topic/21226-another-clutch-question/
why exactly would he send it to QLD when he lives in Sydney?!??
i'm confused...
Lots of people sell heavy duty single plate clutches... Just Jap, UAS etc etc etc ....
The problem could easily appear intermittent but will get worse... Maunal transmissions usually slip in higher gears when the load on the box and clutch is greater.
Adrian
I have never bought a clutch from Just Jap, UAS etc etc etc .... so why would I personally reccomend a company that I haven't dealt with and seen the result of a well built custom clutch, heck you can buy a heavy duty clutch from REPCO so why not buy it from there. I suggested DCS becaus they make the best clutches in Australia....period. Its one of those things, you get what you pay for now and in the future.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
