hey guys i have just had 1 coil break down and as my car is under warranty i can get it replaced at no charge. they offered me to buy splitfires and they would only charge me for 5 and replace them with no labour charge. was just wondering if anybody had some really stuffed coils laying around that i could put on my car so that i could get the cost down a bit more. i figure i have a warranty so why not use it.once replaced i will then have a few good coils here at home for anybody to use or have if ever the need shall arrise.
cheers guys.
https://www.sau.com.au/forums/topic/212352-s2-coil-packs/
Series 2 stagea's use the same coils as a R34 GTT, there are a few sets for sale, approx $150
I would personally get the spitfires, approx $485 a set thru site sponsors, because once 1 of the factory ones starts breaking down, it will not be long before they all do.
I have a set of stuffed ones in Brisbane. Not sure which ones and how many are stuffed, but they were breaking down on only 6psi on the dyno so I replace them with spitfires.
https://www.sau.com.au/forums/topic/212352-s2-coil-packs/#findComment-3752226
mm spitfires.
side note / off topic : Has anyone seen results for JJR's coilpacks.. apparantley they are splitfire replicas and 200 bucks cheaper
https://www.sau.com.au/forums/topic/212352-s2-coil-packs/#findComment-3752614
mm spitfires.
They do not sell them for neo rb's
Time will tell if they will last.
https://www.sau.com.au/forums/topic/212352-s2-coil-packs/#findComment-3752663
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
